Old 02-20-2010, 11:17 PM   #1
travlinman
anyone ever use a aftermarket column shift linkage ?
besides the factory stock linkage's has anyone used a different linkage ?
seen some on ebay some from lokar ? seen a cable linkage and this rod linkage..any experance and how well do they work?
thanks for any input
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 02-20-2010, 11:22 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: anyone ever use a aftermarket column shift linkage ?
Mike's Bump N Grind has them-
http://67-72chevytrucks.com/vboard/s...d.php?t=377990
DPowers is offline   Reply With Quote
Old 02-21-2010, 02:40 AM   #3
travlinman
thanks but does anyone have any experince with any of them ? how well do they work ?
65 Pontiac
69 swb-sold
71 lab sold
Old 02-21-2010, 03:35 AM   #4
leddzepp
Moderator
leddzepp's Avatar
The rod linkage works perfect. I have a 700 R4 in my truck and was able to dial in the shift indicator on the column. Hope this helps.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-21-2010, 05:25 AM   #5
Jbham88
Jbham88's Avatar
Used the lokar in my other truck and it worked perfectly
1986 GMC 4x4
Jbham88 is offline   Reply With Quote
Old 02-21-2010, 06:09 AM   #6
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I replaced a rod-style linkage on my truck with the Lokar cable linkage and it works awesome. Relatively easy to install and you can route the cable pretty much wherever you want so it is out of the way of exhaust, etc.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 02-21-2010, 09:34 AM   #7
stevewhitmore
stevewhitmore's Avatar
I just installed the type in the bottom photo in my 69 and it took a lot of the slop out of my auto column and works good, easy to install.
stevewhitmore is offline   Reply With Quote
Old 02-21-2010, 09:38 PM   #8
Tkmadone
I used the rod in the bottom picture but it is in drive when the shift window says neutral. I couldn't adjust that out, its like the arm on the tranny isn't long enough even though it is adjusted all the way out.
Maybe I installed it wrong somehow...
Tkmadone is offline   Reply With Quote
Old 02-22-2010, 12:54 PM   #9
leddzepp
Moderator
leddzepp's Avatar
There are 2 different size shift rods offered. Sounds like you got the shorter one. The longer one is needed with our trucks.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-22-2010, 07:16 PM   #10
stevewhitmore
I used the longer rod from Kugel Components Kit #KK002 and it was just barely long enough. I only have about 1/2 inch of thread in the ball ends and I hope that is enough and Kugel said 23 1/2 from end to end was all that was available. Just installed it so can't say much more, but I hope it works down the road.
Also at the trans arm you have to install the rod at the end of the arm that attaches to the trans, called the "long stroke" on your column.
Old 02-22-2010, 10:37 PM   #11
68Lowrider
I use the lokar rod and it works perfect, all the indicator PRD21 marks are perfect..... Turbo 400 ... The cable looks like the way to go ....
68Lowrider is offline   Reply With Quote
Old 02-22-2010, 10:38 PM   #12
1LIME69
1LIME69's Avatar
I used the cable style Lokar and hated it. I ruined my powdercoat on my column and figured out it wouldn't work, so now I have a bare spot on my column. The problem I had was that it never seemed to "lock" in a gear. It just seemed to slide through the gears. It never had that definite gear engagment like a rod style linkage does.
"The Ultimate Sleeper" 69' SWB, Holley EFI 525 ci. BB, TH350, 3.73 Eaton posi/Moser axles, 1350 diveshaft, Vintec's 20"x8.5" and 20"x12", OPP windows, CPP rear coilover conversion
1LIME69 is offline   Reply With Quote
Old 02-23-2010, 10:11 AM   #13
travlinman
thank u everyone for ur input. think I'm leaning towards the rod style linkage. hopefully it works as well for me.
65 Pontiac
69 swb-sold
71 lab sold
