Old 02-21-2010, 05:09 PM   #1
CARR33
Spare tire
I just bought a bastardized 67 c-10. When i looked under the rear of the bed i noticed there was no spare tire, and no provision to put one. The p o had installed a tow hitch that bolts to the frame and has a bar running through the area where a tire would probably hang. The bar is welded to a crossmember behind where i think the spare should go. The rear crossmember was nothced for clearance and the removable part of the hitch would have to go through the license plate. I guess at one time the truck was run without a rear bumper because the one on it partially covers the opening for the hitch. All of this trash is leaving the vehicle. How can i mount a spare?
CARR33 is offline   Reply With Quote
Old 02-21-2010, 05:14 PM   #2
burb71
Active Member
Re: Spare tire
There was also an optional in bed spare tire mount
It mounted in the bed towards the front on the drivers side.
burb71 is offline   Reply With Quote
Old 02-21-2010, 06:02 PM   #3
Hammer500
Hammer500's Avatar
Re: Spare tire
Did the in bed spare tire have to be mounted in any particular location? I have seen them in the rear and on either side.
69 Chev C/10 350/200 4R LWB
69 Chev K/20 4x4 350/4sp LWB
69 GMC Sierra Grande 396/400 LWB
Hammer500 is offline   Reply With Quote
Old 02-21-2010, 06:25 PM   #4
burb71
Active Member
Re: Spare tire
I have had two trucks with the this factory option and this is the spot.
Also shown in this spot in the factory assembly manual.
But I guess you can move it to a different spot.
Old 02-21-2010, 09:32 PM   #5
CARR33
Re: Spare tire
I was looking for tailpipes and one of the pictures showed pipes runnung to the rear bumper and it showed a tire in the area where a lot of people mount a blazer gas tank to get it out of the cab. I thought maybe this was a factory location, but the bed sounds so much easier. Thanks
