Old 02-21-2010, 05:48 PM   #176
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Air Ride Install - '69 Chevrolet SWB Stepside
Originally Posted by TrixR4Kids View Post
This is the road I am thinking about with my stepper, great info. Subscribing..
us stepside guys really don't have a lot of room to mount our air ride hardware. you have inside the bed or the frame rails. I'm trying to get everything in the spare tire region. think stealth....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-21-2010, 06:22 PM   #177
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Looking good man
Just a good clean truck, I like the way you are setting it up now, it looks good & goes with the truck
It really gets into a LOT of work going lower than that
Killer has a 6" Z in the rear, 3" cupped LCAs, 2.5" drop spindles & still doesnt lay on 29" tall tires... Plus I shaved my firewall for clearance
But I think Ima finish it up that way for a lil while till I build it a custom frame
I wont build another set of 3" deep cups for the front again tho, they hit the ground first & it doesnt let it lay out as far as it could
They would be good for a static air drop or somebody that doesnt wanna lay out tho
I plan to plate the bottom of my next LCAs & cut the inside out of the arm, then brace it up with some 8" pipe, that way nothing on the arms hangs down lower than stock
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-21-2010, 06:27 PM   #178
tcb-1
tcb-1's Avatar
spray,
you were one of the several that inspired me to go air. your fab work is sick. glad you stopped by to gander at my beater.
Doug
Old 02-21-2010, 07:13 PM   #179
sourkraut
sourkraut's Avatar
doug, awesome build thread! I have no idea how I had missed this! I have just read your whole thread and it is looking good, keep up the good work!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 02-21-2010, 07:50 PM   #180
TrixR4Kids
TrixR4Kids's Avatar
I have static dropped trucks before, the whole air ride conversion is intimidating but some well written (with pics) posts kinda takes the unknown away. There are some awesome rides and help on this forum. Stealth is good.
~ Dave
'68 C10 Stepside: 350/700R4
TrixR4Kids is offline   Reply With Quote
Old 02-23-2010, 12:22 PM   #181
Slick67
Sofa King Crazy!!
Slick67's Avatar
One of my favs. I like the cleanliness!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-23-2010, 01:17 PM   #182
crakarjax
crakarjax's Avatar
Super low-buck compressor - $19
I am sporting an evil grin right now... check out this thread
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-24-2010, 06:53 PM   #183
packrat42
packrat42's Avatar
Thats just bad ass.
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline   Reply With Quote
Old 03-06-2010, 05:43 PM   #184
tcb-1
tcb-1's Avatar
got some wiring done today. one more thing off the checklist. we're gettin' there!
I decided to wire the valves up with 4 conductor trailer wire. pretty cheap, .79 a foot at Napa. went with 10 gauge primary wire from the battery to the relay and from the "unfused ignition" plug on the fuse block to the relay. I used stick-on nylon strap bases so I didn't drill multiple holes in an otherwise solid cab.
disclamer. I like wiring. I'm just weird like that.
and
once the main harness runs out of the rear of the cab, I attached it to the existing brake line.
thought I'd take a few pic of the tank plumbing. I notched the frame a bit so the 5 gallon AVS tank would sit centered between the frame rails..... and what's nice is the the fittings are now protected from rock kickups and roadkill.....
compressor leader to tank interface:
pressure switch to tank interface:
to keep my greasy paws off the switchbox controller, I had a thought last night while having a C & C. like?
next stop, valve bank and final plumbing.
to be continued.
Doug
Old 03-06-2010, 06:01 PM   #185
big_al_71
big_al_71's Avatar
Doug,,,,,that wiring looks totally awesome great job..........
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-06-2010, 07:32 PM   #186
sourkraut
sourkraut's Avatar
excellent work Doug! I love wiring too, people usually do think your nuts to like it! (until they need help with it)
Old 03-06-2010, 10:07 PM   #187
Rochlow
Perfect, now I know what to do with all my CR baggies...
Even though I've bagged a few trucks, this thread has alot of helpful info dealing with 67-72 styles..
Rochlow is offline   Reply With Quote
Old 03-07-2010, 12:20 AM   #188
powell72
powell72's Avatar
Well Doug, it looks like if people want to make money in the stock market they should buy stock in zipties before we do wiring jobs.
Good job, nice clean install as always.
Is it bad that I new what a C&C was before I even saw the pic???
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-07-2010, 09:59 AM   #189
tcb-1
tcb-1's Avatar
Chris,
I knew you'd appreciate my madness...... we would have been retired now if we came up with the nylon wire wrap idea. oh well, should've, would've, could've.
oh, and C&C is the international language of Friday nights at my place!
Doug
Old 03-07-2010, 09:59 AM   #190
nuke1
nuke1's Avatar
Great job Doug, nice and clean, and who can complain about a C&C!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-07-2010, 04:06 PM   #191
tcb-1
tcb-1's Avatar
call me crazy, but I think I found another set of rims so these may be up for sale. keeping the 17" tires though.
I'm never satisfied......
Doug
Old 03-07-2010, 08:55 PM   #192
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Doug... mad attention to detail, however, I wouldn't expect anything less.
You've got me curious on the new shoes consideration though.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-07-2010, 09:10 PM   #193
SCOTI
SCOTI's Avatar
I agree.... Shouldn't there be some sort of rule against swatting the bees nest?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-07-2010, 09:43 PM   #194
tcb-1
tcb-1's Avatar
I know, I know. I'm up to 4 different sets of steelies in 3 years. oh and that's not including the oem 15" x 6" that came when I bought the truck. I found wheel fabricator that can whip up a set 17" x 7" oem steelies with any backspace I want and 6 x 5.5 bc. decisions, decisions.
okay, I am sick. I take medication. I'm a steel rim addict. there it's out! wait....... I hear sirens coming.
gotta go.......................
Doug
Old 03-07-2010, 09:44 PM   #195
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Edit... caps?
-Nate
Old 03-07-2010, 09:45 PM   #196
tcb-1
tcb-1's Avatar
didja halfta ask?!!!
Doug
Old 03-07-2010, 09:54 PM   #197
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Edited... nope.
-Nate
Old 03-07-2010, 10:08 PM   #198
Security guy
Security guy's Avatar
Good info! I may be doing this in another year. Love your truck!
Security guy is offline   Reply With Quote
Old 03-08-2010, 08:40 PM   #199
powell72
powell72's Avatar
Steelies rule, you know it, I know it, and people that don't agree just don't get it!
Chris
Old 03-08-2010, 09:15 PM   #200
kyull67
kyull67's Avatar
You know I'm gonna have to air ride my stepper now.... Looks Awesome!
kyull67 is offline   Reply With Quote
