Old 02-22-2010, 01:52 AM   #1
wholio
wholio's Avatar
1969 k5 build allout!
I Just recently bought a 1969 k5 4x4 as a project im planning on doing a frame up restoration.
im trying to remove the body off the frame but someone on here told me to add support to the actual body i was just wondering if someone could help or point me in the right direction
ive only had if for a week so far and ive remove basicly everything bout the body it self off the frame
Heres my post so u can see where and what ive done so far
http://67-72chevytrucks.com/vboard/s...d.php?t=387300
wholio is offline   Reply With Quote
Old 02-22-2010, 07:33 AM   #2
vtblazer
vtblazer's Avatar
Re: My Restoration Begins on a 1969 k5
Welcome to the board, the best advise I could possibly give you is to sit down and start reading.
Lots of threads here dealing with your question.
(yes, the tub 'should' be supported for the best outcome)
vtblazer is offline   Reply With Quote
Old 02-22-2010, 04:19 PM   #3
wholio
wholio's Avatar
thanks
any idea where to add the support tho?
Old 02-22-2010, 04:29 PM   #4
lks dcvn
lks dcvn's Avatar
Here is a great example for bracing [somebody provided it in your other post in the truck forum] - it even includes the ability to dial in the gaps when doing the welding.
http://67-72chevytrucks.com/vboard/s...8&postcount=54
http://67-72chevytrucks.com/vboard/s...1&postcount=55
http://67-72chevytrucks.com/vboard/s...4&postcount=64
How bad is the rust on the body? Have any more pix?
lks dcvn is offline   Reply With Quote
Old 02-22-2010, 05:11 PM   #5
vtblazer
vtblazer's Avatar
Bracing done correctly.
Old 02-22-2010, 05:41 PM   #6
wholio
wholio's Avatar
its pretty bad
i have to replace the front floor panels and alot of body work ill post some pics and the next post
Old 02-22-2010, 06:27 PM   #7
wholio
wholio's Avatar
heres some pics
Old 02-22-2010, 06:29 PM   #8
wholio
wholio's Avatar
heres more
Old 02-22-2010, 06:34 PM   #9
wholio
wholio's Avatar
heres
Old 02-22-2010, 06:46 PM   #10
k5hart
k5hart's Avatar
Welcome to the board! Your in a great place for information. Search and read post here and you will find just about any answer your looking for. Can't wait to see what you do with the blazer. What did you do with the half top? Any pics of it?
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 02-22-2010, 07:53 PM   #11
lks dcvn
lks dcvn's Avatar
wow that does need some work - it is all fixable/replaceable - just takes time and $
Old 02-22-2010, 11:09 PM   #12
wholio
wholio's Avatar
well im dedicated to fix it
Old 02-26-2010, 12:00 PM   #13
wholio
wholio's Avatar
i just recently bought a donor truck 2wd
so im goin to do the 2wd conversion on my truck
what all do i need to put the 2wd on my blazer
someone told me that the 4x4 frame and the 2wd frames are different ?but how?
Old 02-26-2010, 12:14 PM   #14
wholio
wholio's Avatar
heres some todate pictures
Old 02-26-2010, 12:23 PM   #15
lks dcvn
lks dcvn's Avatar
This link gets posted all the time...
http://www.sporttruck.com/techarticl...ion/index.html
More info:
http://67-72chevytrucks.com/vboard/s...ght=4wd+blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=327847
Did you buy a 5 lug disk brake truck or stay with 6 lug stuff?
Old 02-26-2010, 12:31 PM   #16
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Lookin' good. Keep the pics coming!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-26-2010, 12:38 PM   #17
wholio
wholio's Avatar
More info:
its a six lug
Old 02-26-2010, 01:12 PM   #18
wholio
wholio's Avatar
or should i update to a 5 lug?
Old 02-26-2010, 04:05 PM   #19
lks dcvn
lks dcvn's Avatar
depends on what you have available...and how in depth you want to go.
If I ever do one...I will do the following:
2wd front xmember swap from a 73-87 chevy truck taking all steering components, linkage, and brake stuff - so you get disk brakes and more plentiful/cheaper front end parts when rebuilding the front end.
Rear - find a 5 lug leaf Spring rear and swap the axle out and then put the axle on top of the leaf springs.
Old 02-26-2010, 04:40 PM   #20
wholio
wholio's Avatar
what all do i need to do a drum to disc brake conversion?
Old 02-27-2010, 01:56 PM   #21
1956cameo
1956cameo's Avatar
Hey wholio, Welcome to the board from a fellow blazer owner. What part of Houston are you in? I am down here in Pearland.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 02-27-2010, 02:06 PM   #22
wholio
wholio's Avatar
i live in Pasadena
Old 02-28-2010, 03:18 PM   #23
wholio
wholio's Avatar
OK basically i been doing a little thinking, i need some advise, on my truck the floor panels, rocker panels, kicker panels, some of the fire wall, window pillards ect.. are F**ked up but on my donor there in perfect condition, i was wondering if i could some how cut my donor cab all the way to back wall of the donor truck and just replace it, or should i slowly buy everything new?
im going to attach pictures to better say what im trynna do, the blue area is where im tryin to cut
Old 02-28-2010, 05:16 PM   #24
1956cameo
1956cameo's Avatar
I would replace everything you can from a donor vehicle. It takes a little more time but saves money and everything seems to fit back together better in my opinion.
Old 02-28-2010, 05:25 PM   #25
Monte Carlo Man
You can get floor pans cheap - cheaper then you could scab floor pans out of a old truck.
I would look at Raybucks catalog to see if they were available.
http://raybuck.com/
I have know Randy Raybuck since the days when he worked for T.W Phillips gas and oil and built VW Rabbits in his garage in his spare time. They are a slip fit, no hassles install.
Monte Carlo Man is offline   Reply With Quote
