Old 02-22-2010, 09:12 AM   #1
nac593
HEI distributor keeps going out. WHY?
so i replaced EVERYTHING 12000 miles ago. new engine(290 hp crate), distributor from chevy dealer.and everything under the hood is new. ir ran great and then at about 5000 miles it just cranked and cranked with no spark. I changed the coil with parts from napa. it started right up. at about 8000 miles same exact thing. jumped in to start it and it just cranked. bought coil from kragen and it started right up. now i am at 12000 miles. jumped in last night and same thing.just cranks so i assume its the same thing. WHY does this keep happening?
nac593 is offline   Reply With Quote
Old 02-22-2010, 09:22 AM   #2
rockc
Re: HEI distributor keeps going out. WHY?
Had the same thing happen to me. Tried rebuilding it myself. Kept replacing a coil, mod, cap, etc, So ended up buying a new rebuilt dist. from checkers for around a $100. That was 40000 miles ago and still running good. Might check amount of voltage to it also.
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 02-22-2010, 09:52 AM   #3
cdowns
cdowns's Avatar
when installing HEI you did run a new power supply line? have you ever cleaned and checked ALL your ground connections? have you used the GREASE when replacing modules?
Old 02-22-2010, 09:58 AM   #4
drbyrdman
drbyrdman's Avatar
The stock dist. wire has resistance for points. That will kill a HEI if it was not taken out and replaced so the Hei gets a full 12 volts.
drbyrdman is offline   Reply With Quote
Old 02-22-2010, 10:03 AM   #5
bigblockorange
Check the voltage on the wire to the HEI from the firewire wall. It may be less than 12 volts if so pull the harness and remove the wire and replace it with one from a newer truck 74 and up they are a non-resisted wire. I bought a truck that did the same thing. BBO
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!!
bigblockorange is offline   Reply With Quote
Old 02-22-2010, 11:50 AM   #6
chas350
x2
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 02-22-2010, 11:58 AM   #7
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Make sure the 12V is coming from an ignition-on source. The module doesn't need to see 12V constantly, like if you went straight to the battery.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 02-22-2010, 12:51 PM   #8
Wrenchbender Ret
There is a ground strip that goes under the coil to the center term. on the outside that goes to the dist housing. Sometimes when a guy changes the cap he leaves it in the old cap. It can cause all sorts of component failures.
Wrenchbender Ret is offline   Reply With Quote
Old 02-22-2010, 08:15 PM   #9
nac593
i did run a new 12v wire. and that ground strip is in there
Old 02-22-2010, 08:43 PM   #10
LONGHAIR
That was going to be my answer, I have seen that happen more than once.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-22-2010, 09:22 PM   #11
cparman
sharp as a marble
X3 I have seen this drive some really good techs crazy. Make sure it is there.
cparman is offline   Reply With Quote
