02-22-2010, 09:37 PM | #1 |
3/4 Ton Rear End Help Please
Can somebody check out this link and tell me if this would fit my 67 C20?
I see the brackets on the axle but don't think it is a trailing arm set up like my C20. http://moncton.kijiji.ca/c-cars-vehi...AdIdZ178399214
If your not living for something, your dieing for nothing... |
02-22-2010, 10:39 PM | #2 |
Watch out for your cornhole !
Re: 3/4 Ton Rear End Help Please
That's not a coil spring rearend. It's out of a later leaf spring truck.
02-22-2010, 11:15 PM | #3 |
TOTY 2006
Not a bolt in, but if you have any fab skills, $30-40 for new perch mounts depending whom you order from, access to a welder and understand how to degree a rear end, you can make this work. dont forget that you may need to either get a new driveshaft or using a different rear ujoint to make this work as well.
