Old 02-24-2010, 01:59 PM   #1
steinepstein
Dimensions for converting rear from leaf to coil
I'm converting my 68 GMC from leaf to a trailing arm setup....
Does anyone have trailing arm perch dimensions? Those perches are welded on at an angle and are set at some distance from center. I'd love to get those dimensions, any help would be appreciated.
I realize that I could take the truck to a chassis shop and they could line everything up straight and square and weld it all up, but I'm not at that point yet and don't really want to haul it all over there either.
If I am going about this wrong, please let me know, thank you.
steinepstein is offline   Reply With Quote
Old 02-24-2010, 02:29 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Dimensions for converting rear from leaf to coil
I have requestd this info too in the past. SCOTI is working on getting me this. If he does, he may post it here too or I will pass it along. He has a chassis sitting on a table while he is setting it up.
Another way, is to put in the crossmember, install the trailing arms in a position that keeps them from binding in the front mount. Set the saddles on the arms, set the rear end on them and set the pinion angle, then weld them up. I sort of did this when I put my 9" under mine. I just happened to start with a truck that was coil to begin with.
Hopefully, I will get the measurements soon.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-25-2010, 02:19 AM   #3
fixit-p
fixit-p's Avatar
If your refering to the brackets which bolt to the TA cross member I have it on a disc I check tomorow as far as the cross member it should already be there IIRC my 65 GMC with leafs has it and it's already drilled for the brackets
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 02-25-2010, 09:46 AM   #4
Wild83C10
Wild83C10's Avatar
That is the way CPP did it on their 79 conversion and that is how I am doing mine. Having the dimension as a reference isn't a bad idea but it doesn't mean yours will sit at those exact dimensions.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-25-2010, 11:51 AM   #5
steinepstein
thanks guys!
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216
Old 02-25-2010, 01:38 PM   #6
fixit-p
fixit-p's Avatar
Not sure if this is what your looking for, but here it is. My 69 3/4 ton with leafs also already has the TA x-member. I also have a pdf if this isn't readable
Old 02-25-2010, 01:42 PM   #7
steinepstein
fixit,
thank you, this is also a valuable drawing, but more specifically, I'm looking for the perch dimensions from the rearend - distance from perch to perch and angle of perches
thanks,
JE
Old 02-25-2010, 01:53 PM   #8
fixit-p
fixit-p's Avatar
Ahh, I'm at the wrong end, I too need that info so I'll stay tuned and if I find anything out I'll be sure to share.
Old 03-01-2010, 06:08 PM   #9
aggie91
aggie91's Avatar
SCOTI got this information for me. He measured the center to center of the rear hole of the axle pad to be 41.5" and the center to center of the front hole in the pad to be 39.5".
I will be doing a layout of this in autocad and could send out a PDF if someone needs it. I will get the rest of the info I need tonight to do the layout.
Karl
The LST Challenge:
Old 03-01-2010, 06:21 PM   #10
SCOTI
SCOTI's Avatar
Get @ least one more confirmation on the dimensions first (I could be cross-eyed ).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-01-2010, 06:44 PM   #11
steinepstein
Greatly appreciated. Please let me know if you ever need a favor, happy to help.
Old 03-01-2010, 07:15 PM   #12
fixit-p
fixit-p's Avatar
If you don't mind I would like a copy.
Old 03-23-2010, 11:58 AM   #13
m6z
m6z's Avatar
Does anyone know if the leaf spring trucks have the holes predrilled for the trailering arm crossmember?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 03-23-2010, 12:22 PM   #14
SCOTI
SCOTI's Avatar
67-72 leaf equipped trucks should already have the TA c.member installed (w/o the TA brackets). That c.member was also used for mounting the carrier bearing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
