Old 02-24-2010, 06:41 PM   #1
BukuBandits
BukuBandits's Avatar
cadillac 500
i have an 84 3+3 with sm465 putting a cad 500 motor in does anyone know if i can use the mid sump pan thanks.
1984 3+3 350/sm465 2wd
BukuBandits is offline   Reply With Quote
Old 02-24-2010, 06:57 PM   #2
Slofarmtruck
Re: cadillac 500
A mid sump should work for you. Its what was used in my 86 and a friends 94 Chevy trucks.
Slofarmtruck is offline   Reply With Quote
Old 02-24-2010, 07:12 PM   #3
BukuBandits
Re: cadillac 500
what major mods have to be done besides flipping the sbc mounts and the driver side firewall cutting
Old 02-24-2010, 07:26 PM   #4
Slofarmtruck
Re: cadillac 500
I don't recall having to cut the firewall, but than again the previous owner of my truck had a caddy motor in the truck before I bought it from him. I bought the truck with a sbc that blew a head gasket so we decided to go the caddy route again since he had all the swap parts. He didn't flip the motor mounts as he had made some steel adapter plates to bolt the stock caddy mounts to. We also ran a set of Sanderson headers that were suppose to be a direct fit. We ended up having to trim the frame some and hammer in a few of the header tubes to fit properly. The only pics I have since I had no digital camera than are in this link...
http://67-72chevytrucks.com/vboard/s...d.php?t=384957
Old 02-24-2010, 07:27 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: cadillac 500
A Caddy 500 weighs less than a 454! You can find performance parts and info at http://www.500cid.com/Home.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-24-2010, 07:44 PM   #6
BukuBandits
Re: cadillac 500
ive already talked to marty on what cam i should use for towing from there
Old 02-24-2010, 07:57 PM   #7
78 Chevyrado
Re: cadillac 500
I think there may be some clearancing needed around the oil filter (RH front).
78 Chevyrado is offline   Reply With Quote
Old 02-24-2010, 08:14 PM   #8
BukuBandits
Re: cadillac 500
will i have to do any cutting or will a 10 pound hammer work
Old 02-24-2010, 08:28 PM   #9
Slofarmtruck
Re: cadillac 500
I think that depends on which filter housing he uses. I beleive a 425 housing will allow more clearance. I can't recall what we had used but will try and find out for you.
Old 02-24-2010, 08:53 PM   #10
BukuBandits
Re: cadillac 500
also does anyone know how well the sm465 will hold up
Old 02-24-2010, 09:39 PM   #11
Slofarmtruck
Re: cadillac 500
I am usure how well that trans will hold up. I know that there are very few manual transmission that can handle the torque of the caddy motor. I was researching running a Muncie 4 speed in my new project car behind a caddy motor and ended up choosing a TH400 for now, since my results yielded transmissions that were way out of my current price range. For sure a Tremec TKO600 will hold the power but they cost $$$. Might want to contact the guys at Cad Company with your trans question. http://www.cad500parts.com/
Old 02-24-2010, 09:44 PM   #12
78 Chevyrado
Re: cadillac 500
if you use a manual tranny you'll have to machine the rear of the crank to accept a pilot bearing since they all came with auto trannys.
Old 02-24-2010, 10:01 PM   #13
Pyrotechnic
Pyrotechnic's Avatar
Re: cadillac 500
The SM465 is very strong. The gear set is pretty heavy, which lends itself to strength but it also stop you from doing any power shifting, which again will make the trans live longer.
You could probably use a BOP bell housing, but I believe the opening for the input bearing retainer with have to be machined larger, as the input bearing retainer on a SM465 is larger than that of a car transmission
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-24-2010, 10:25 PM   #14
Slofarmtruck
Re: cadillac 500
Talk to the Cad Company as they have alot of manual trans swap parts. Their Billet Steel Flywheel is a thing of beauty!
Old 02-25-2010, 11:30 AM   #15
BukuBandits
Re: cadillac 500
i called cad company last week on the trans adapter and flywheel total cost is about 500 but he said it is a direct bolt up and do not have to machine the crank for a pilot bearing i know they have everything needed for the swap. and obviously this truck isn't going to be taken to the track or anything but i would like to get on it here and there and not worry about the tranny blowing apart
Old 02-25-2010, 12:04 PM   #16
BukuBandits
Re: cadillac 500
just got off the phone with cad company trans will definitely hold up to the abuse
Old 02-25-2010, 01:29 PM   #17
Slofarmtruck
Re: cadillac 500
That is great news!! Please post pics of your progress!
Old 02-26-2010, 11:40 AM   #18
BukuBandits
Re: cadillac 500
can anyone post some pics of motor mounts or trans adapter hooked up
Old 02-26-2010, 10:00 PM   #19
spinem
haha, ford guys...
Re: cadillac 500
i remember seeing a 67-72 build years ago.... never this year.. PICS!
spinem is offline   Reply With Quote
Old 02-26-2010, 10:40 PM   #20
Slofarmtruck
Re: cadillac 500
Mine was in an 84 C10 with a TH400 trans behind it. These are the only pics I have. Hope they provide some help.
You can see the breather on the drivers side under the vacuum booster is crushed in so that it would fit.
Old 02-28-2010, 09:03 PM   #21
BukuBandits
Re: cadillac 500
thanks for the pics and how much diff are the mounts for the 67-72
