Old 05-07-2003, 01:33 AM   #26
Jackal2k9
Jackal2k9's Avatar
crazy L you are crazy.... but when i need to rebuild my trans im gonna call you for more tips.
Jackal2k9 is offline   Reply With Quote
Old 05-07-2003, 01:52 AM   #27
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Rounded or stripped out phillips head screws....Take a hack saw or cutoff wheel and cut a slot in the head so you can use a straight screwdriver on it.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-07-2003, 01:53 AM   #28
O'l Buck
O'l Buck's Avatar
Lazy drive pin for the fuel pump keeps falling down when you try to install the pump. Use a cut off hacksaw blade to hold it in place while you slide the pump in.
Chad
Old 05-07-2003, 02:18 AM   #29
67cst
i love summertime
67cst's Avatar
RIVET REMOVAL PART #2
I have found that this method im about to explain is hands down the fastest and easiest way to remove a rivet, the way ive been shown from my dad is to center punch the rivet in the center of it or close as possible, then drill a pilot hole through it then get a bit that is roughly the size of the hole the rivet is going through, then drill the rivet just enough ( bout half way though ) you will know when you have achieved this because the mushroomed or top part of the rivet starts spinning, once this happens stop drilling, get your punch and a hammer and tap the bottom half of the rivet out the opposite side you drilled from
sounds complicated but try it, its awesome and doesnt require a cold chisel and swolen fingers
DEREK
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 05-07-2003, 08:58 AM   #30
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Great post!
I actually added a tips/tricks page to my site. Check out my collection here---> http://www.348-409.com/tips.html
You guys mind if I add a few of yours to my page? There are some good ones here.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-07-2003, 10:36 PM   #31
weasel29gm
SLOW BUT SURE,BUT CLOSER
Cheap knee pads
Use the cardboard packin' out of stove,fridge,tv etc. They are thick and good to use for sandin' in a bed,on floor etc. I got em' from the air compressor, and just got done usein'em' on my bed floor. Worked great!!!!!
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 05-07-2003, 11:15 PM   #32
sgtjed
What if?
sgtjed's Avatar
here is one for ya. when you change the thermostat out and dont have a gasket. use the the cardboard box of a 12 pack of coke.
its thin enough and works in a pinch,i also have used spent ammo brass as gasket cutters for the bolt holes.
2002 red extended cab Silverado
2002 Wheatland yellow Suburban
sgtjed is offline   Reply With Quote
Old 05-08-2003, 12:48 AM   #33
pissonNOS
senior member
pissonNOS's Avatar
asbestos also works great for gaskets.
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 05-08-2003, 03:31 AM   #34
jimfulco
Another good thing for carb gaskets is Permatex Super 300 (formerly Aviation Permatex #3). Brushes on, gas won't eat it, alcohol cleans it up, & old cheap gaskets peel away unharmed even after several years.
And chamfer that spent brass first, it will cut better.
jimfulco is offline   Reply With Quote
Old 05-08-2003, 03:35 AM   #35
jimfulco
Use a refrigerator box under the car instead of a creeper. More ground clearance and you can slide around instead of fighting those weird creeper wheels.
Old 05-08-2003, 12:02 PM   #36
Figment412
Cheap hockey pucks make a good spacer for increasing body lift.
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 05-08-2003, 12:13 PM   #37
COBALT
COBALT's Avatar
Presetting new points gap...
Hah! That last one is funny.
Here's one. If you don't have a .019 90 degree feeler guage to set the appropriate gap in your new points use a match book cover. The cardboard is roughly the right thickness, and will allow you to get in the right ballpark. Then start the motor, open that little door, and set the dwell angle (if no dwell meter, set it to the best sounding RPM).
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-08-2003, 12:18 PM   #38
COBALT
COBALT's Avatar
Setting Carb Idle Mixture screws...
Here's the way I do it (requires an external Tach):
1. Get the truck running to operating temp.
2. Set the idle screw on the driver's side accel. linkage to the appropriate RPM (800-1000 RPM).
3. Start with one side. Start to screw the mixture screw in until the RPM starts to drop enough to run rough. That's your min. Screw it out until the RPM is at max.
4. Do the same on the opposite side.
5. Reset your idle screw on the accel linkage back to the right range.
That's it! You're done.
Seattle, WA.
Old 05-08-2003, 12:51 PM   #39
COBALT
COBALT's Avatar
Fool-proof distributor replacement
When yanking the distributor for whatever reason if you want to put it back in later, or you're simply replacing it with another distributor of the same type here's an easy way to make sure you put it back in exactly the way it came out so timing and adjustment is EASY.
1. Take the #1 plug wire in your hand. Follow it up to the distributor cap, and mark the cap with a piece of tape, a file, or some white paint.
2. Take the plug wires off the distributor.
3. Remove the Neg. wire off the coil from the distributor.
4. Remove the distributor cap and set it aside.
5. Take a ruler, and lay it edge down along the contact on the rotor. Point it to the firewall until the ruler touches the wall in the hump. Use a black marker, piece of thin tape, or something else that will leave a removable impression on the firewall exactly where the edge of the ruler is pointing.
6. Double-check to make sure the contact on the rotor (and it's orientation: toward the firewall or away from it), the ruler, and the mark all line up (take a picture of the setup if necessary - use a piece of string to hold the ruler to the rotor if necessary).
7. Remove the distributor hold-down, and slide the distributor out while turning it.
...now when putting the distributor in.
1. Slide the distributor into the engine until it's obstructed.
2. Turn the rotor until the contact on the rotor is roughly 45 degrees from your mark counter-clockwise.
3. Turn the distributor and continue to slide it down until the contact on the rotor is pointing at your mark on the firewall (you may have to pull the distributor out a bit, turn the rotor, and reinsert until you get this right!).
4. Use your ruler to verify that the contact on the rotor is pointing EXACTLY at the mark you made on the firewall. If it's not pull the distributor out, turn it, and keep putting it in until it is.
5. Reinstall the hold-down, and only tighten enough so you can turn the distributor for timing.
That's it! Once it's aligned put your distributor cap back on, put on your #1 plug wire. Install the rest of the wires in the right firing order, and it should start right up. Time the motor and you're done.
Seattle, WA.
Old 05-09-2003, 03:59 PM   #40
Mike Culpepper
Red
Mike Culpepper's Avatar
Just replaced the "CHEVROLET" letters on my tailgate trim, those push nuts were a bugger to get on the letter posts.
I ended up using a C-clamp with a 4" throat depth. I hot glued a 1/4" drive socket onto the thread end of the clamp ( I forget the size -but the socket rim should just ride on the rim of the push nut) . I put the nut onto the socket and held it up to the post. I protected the letters on the other side of the trim piece with a thick rubber pad off a woodworking clamp I have. Makes a quick and easy "press fit", and went alot faster than the grunt method I started with.
Mike.
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 05-10-2003, 02:56 PM   #41
SEVEND2
SEVEND2's Avatar
OK First get a Large Tarp or Plasic sheet, line the inside of your bed of your truck (as shown below) then fill with water (as shown below) then jump in!!
This is Called
Shown Below
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 05-10-2003, 02:58 PM   #42
SEVEND2
SEVEND2's Avatar
PS. THAT IS NOT ME IN THE BED, Just thought it Fit in this POST!!!
and stage 2
Old 05-10-2003, 06:36 PM   #43
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Two twists on the tips listed.
(1) Spring loaded chuck keys.They push themselves out with spring pressure to keep you from turning the drill on with the key in the chuck.
(2) Push nuts are easy to put on with worn out nutdrivers.Use the one that fits the outer edges of the nut.
New tip; when trying to remove a broken bolt use a nut and weld thru the center of it to the bolt.The nut will give you a place to put a wrench and the heat will release most siezed bolts(unless crossthreaded).Works well on bolts broken off too short to grip with vise grips.Also works well when you don't have room to get the drill in to drill and easy-out the broken bolt.
Brake cleaner works well as a pre paint prep for small parts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-11-2003, 11:26 PM   #44
casey
casey's Avatar
works for me
This is Called
Shown Below
on a real hot day why not
casey is offline   Reply With Quote
Old 05-12-2003, 12:58 AM   #45
SEVEND2
SEVEND2's Avatar
I did that last summer for my 2 girls, just cause they heard about it at school, I ended up with about 10 kids in the back of my 81 longbed chevy,
Empting it i drove out to the road and slit the plastic at the Gate and drove off, washed down the road as i went!!
and stage 2
Old 05-12-2003, 02:58 AM   #46
72addict
Radiator draining
replace the original pitcock on the radiator with a pitcock that has a threaded fitting on the output side also. When it is time to drain the radiator, screw a hose on the fitting, and neatly drain the radiator without it running all over. This also works with the drain plugs in the block. May want to put caps on the pitcocks so they dont leak when not in use.
Also, on draining fluid from tranny's with stock pans (w/o drainplug) put a hose down the dipstick tube and syphon the fluid out. This helps eliminate the mess of removing the pan when the tranny is full.
1957 Cameo
72addict is offline   Reply With Quote
Old 05-12-2003, 03:25 AM   #47
jimfulco
Siphon idea sounds cool. Less ATF in the mouth too, I bet.
Old 09-23-2003, 10:23 PM   #48
Shane
Shane's Avatar
I had forgotten about this post ... ran up on it while looking under my UserCP page.
If anyone has any neat tricks, short cuts or other ideas, please add them.
Anywhoo ... TTT
Shane is offline   Reply With Quote
Old 09-23-2003, 10:47 PM   #49
Eddie H.
Eddie H.'s Avatar
To keep from stripping out tight, hard to remove phillips head screws.
dip the screwdriver tip in fine valve lapping compound first.
The grit helps keep the screwdriver tip from slipping.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 09-23-2003, 10:48 PM   #50
lukecp
Formerly yellow72custom
lukecp's Avatar
Inside the cab of your truck, just above where the passenger side seat belt bolts to the floor, there is a little round hostler thing just below the back glass
It is a perfect fit for holding a 4D Maglite! Easy to get to, so if your truck dies in the night, you can easily feel to get for it. Also easy to get to if you need to use it as a weapon
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
