Old 03-02-2010, 04:17 PM   #1
redbaron69
redbaron69's Avatar
need help rear axle questions
man here in town has a 5 lug 12 bolt leaf rear axle for sale. he claims it come from a truck and i going to look at it. my 69 is leaf rear and i want to use it for my 5 lug swap. what are the differences from a 67-72 leaf rear and a 73 up? are they the same width from back plate to back plate? just dont want to buy something i cant use. thanks for any help
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 03-02-2010, 04:24 PM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: need help rear axle questions
I know that the leaf spacing is different between a 67-72 and a 73-?. other than that I think that the 73+ have a 10 bolt not a 12 bolt, that is easy to spot . Other than that I don't think there is much difference, you could take a 10 bolt and move spring perches and it would bolt up from what I've read. Good luck and I hope he has was you're looking for!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-02-2010, 04:30 PM   #3
redbaron69
redbaron69's Avatar
yea stuff like that. i can measure the distance on my axle between the leafs a check for a difference. i think i see a post were somebody said the leafs were different widths? anybody know??
Old 03-02-2010, 06:06 PM   #4
capev86
do the mods mentioned above and you'd have the more modern 10 bolt rear under your truck. don't worry about a wider track width as the front is always wider anyway on a stock setup. especially on a 4x4 with the front wheels that stick way out, a wider rear would make it look more balanced.
capev86 is offline   Reply With Quote
Old 03-02-2010, 06:26 PM   #5
ERASER5
ERASER5's Avatar
Not all. There are plenty of GM12 bolts on 73+ trucks.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-02-2010, 07:56 PM   #6
Jacfourteen
I didn't know that. Are they the same internals, axles,etc as the earlier ones?
Old 03-02-2010, 08:49 PM   #7
redbaron69
redbaron69's Avatar
thanks for the responses guys. my truck is a 2wd if they was some confusion there. i have seen the replacement axles you can get from ECE but i can get this rear cheaper. does anybody know about the width of the springs?
Old 03-02-2010, 09:07 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I know on the heavier trucks there was more than one width of leaf spring.
Look at the shock mounts, if staggared, then it was certianly out of a later truck.
Old 03-03-2010, 02:51 AM   #9
ERASER5
ERASER5's Avatar
Same as the 72, but as LHM said, the shock mounts are wrong and the spring perches are or might be different.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
