67-72 a/c acc. on 73-87?
is the air conditioning for the 67-72 chevys different then on the 73-87's?
is anything useable at all? thanks in advance
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: 67-72 a/c acc. on 73-87?
the older trucks had the longer compressors but if you had all the brackets you could mount it.. the issue would be the refrigerant lines which MAY have to be custom made, but alot of places can make these up if you search custom hoses. It would prolly be cheaper to use the right set up
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
The 67'-72' trucks used a different type dryer, compressor, refrigerant lines, a POA valve vs. pressure switch, etc. Totally different system. I personally would look for a junker to take the correct system out of instead of trying to retrofit. You will save yourself much money and frustration doing it that way. Good luck.
