Old 03-03-2010, 08:19 PM   #1
kenm78
Broken Down
kenm78's Avatar
1982 Fuel Pump.
I got a 1982 Chevy K10 4x4 dual fuel tanks that originally came with a 305. PO installed a 454 There are two fuel lines going to the fuel pump. Do each of these lines go to a different fuel tank or is one a supply and one a return??
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 03-03-2010, 10:59 PM   #2
Slofarmtruck
Re: 1982 Fuel Pump.
One should be the "in" or supply from the tanks and the other will be the "out" or supply to the carb.
Slofarmtruck is offline   Reply With Quote
Old 03-03-2010, 11:43 PM   #3
lurch115
lurch115's Avatar
Re: 1982 Fuel Pump.
the threaded one goes to the carb. the larger of the 2 unthreaded one is the supply line from the tank(s) and the smaller one is a fuel return line.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-04-2010, 12:16 AM   #4
kwlskid
kwlskid's Avatar
Re: 1982 Fuel Pump.
lurch115 is right. If you chase the lines back to the fuel selector valve you'll see that each tank has a supply and return line to and from it.
Kwlskid
1972 GMC stepside C1500
1982 GMC fleetside C2500
kwlskid is offline   Reply With Quote
Old 03-04-2010, 12:47 AM   #5
Slofarmtruck
Re: 1982 Fuel Pump.
Thanks for the correction. Its been a while since I've looked at a stock setup!
Old 03-04-2010, 07:06 AM   #6
kenm78
Broken Down
kenm78's Avatar
Re: 1982 Fuel Pump.
I was thinking that but was unsure. I kept smelling fuel but couldn't find any leaks anywhere then last night I seen something dripping. Come to find out it was the smaller of the two un-threaded lines. Cut the bad end off and put a new clamp on. Hopefully I won't loose any more gas, the 454 drinks it fast enough as it is.
kenm78
1982 Chevy 4X4
Project truck
Old 03-04-2010, 11:48 AM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 1982 Fuel Pump.
IF you hook up the return line to a stock pump OR use a different lower plate for an aftermarket pump to get the opening for the return fitting. This little line will help on any fuel vaporization problems. I had a problem when I went to a different fuel pump and the reconnection of the return line helped me out quite a bit on vapor locking. It did not completely solve the problem, but a good share of it is now gone.
Frank
