Old 03-04-2010, 12:58 AM   #1
JW76
JW76's Avatar
short vs longbed frames
Is the part of the frame marked by the orange box the same on short and long bed frames? It is just the part before and after that portion that has the extra length correct?
JW76 is offline   Reply With Quote
Old 03-04-2010, 02:06 AM   #2
bluex
bluex's Avatar
Re: short vs longbed frames
Yes it is. To make a shortbed you take out 14" behind the rear cab mount and 5 3/4 off the rear behind the hanger. The section you have marked is the same and is what you have left after you make it a shortbed (well more than you have marked, but you get the idea).
bluex is offline   Reply With Quote
Old 03-04-2010, 02:11 AM   #3
JW76
JW76's Avatar
thanks. exactly the info i was looking for.
Old 03-04-2010, 11:49 AM   #4
C-10 simplex
So, no rewelding required?
C-10 simplex is offline   Reply With Quote
Old 03-04-2010, 03:07 PM   #5
Damien
Damien's Avatar
If you want to have one chassis when you are done cutting there is welding required. 14" needs to be removed from the center of the frame and then the 5" at the rear of the frame needs to be cut off. That does not require welding anything back on.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-04-2010, 04:21 PM   #6
bluex
bluex's Avatar
Ya you have to weld the middle back together...
Old 03-04-2010, 11:23 PM   #7
spinem
haha, ford guys...
I prefer duct tape.
spinem is offline   Reply With Quote
