Old 03-04-2010, 06:57 PM   #1
runuover
how can i convert a 72 to disc
im in the process of bagging my truck and i dont think it sits low enough in the front so i need spindles but my truck has drums
how can i convert my truck to disc w/o having to buy the $900 kit that doesnt even redo the rest of the suspension
i already could use new tie rods and ball joints, is there a way to use newer model stuff w/o costing so much, $900 would be fine if it replaces my whole suspension up front w/ new stuff
i read about the 66 conversion how much of this stuff applys to my truck
thanks
runuover is offline   Reply With Quote
Old 03-04-2010, 07:11 PM   #2
69 longhorn
Re: how can i convert a 72 to disc
Your 72 already has disc s up front.....
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-04-2010, 07:18 PM   #3
runuover
not mine, i have drums and had springs all the way around and power nothing, it was the lowest model of a fullsize i believe
Old 03-04-2010, 07:33 PM   #4
SCOTI
SCOTI's Avatar
GM put discs on trucks as standard equipment starting in 71. If your truck is truely a 72, the front suspension was robbed to be put under an earlier truck & that suspension was swapped back under yours. The other possiblity is the truck frame/suspension is earlier w/a later body on it.
To get discs up front w/o spending for a kit, hit your local wrecking yard (or search Craigslist for your area) for a 71-80 GM truck getting parted out. The parts will easily swap over to your current frame.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
