Old 03-05-2010, 10:18 AM   #76
threeonthetree
threeonthetree's Avatar
Re: First Timers Build/Super Stock 70 Step
nice looking engine did you get her running yet?
paint looks like its going to look really great on your truck!
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 03-11-2010, 07:56 PM   #77
jsmithbm
jsmithbm's Avatar
Not running just yet, i am waiting on the wiring gutters, since i am rewiring for the HEI distr. i thought i would go ahead and install the new gutter (rubber channel that holds the engines wiring harness). Also got a new external voltage regulator and wiring harness.
I need the shift linkage that mounts to the motor. I have also been installing the pulleys and brackets. I have those done but i am still in need of a radiator hose and belts. Once those are installed and the left header i should be able to crank her up!!!
I picked up a gallon of Rage body filler and a tube of metal glaze. Once shes running, i plan on attacking the bed, i have all new bolts and nutz for it. However the wood maybe the last thing i do before or after i paint. I think i should paint the bed before i install the new wood. I hope to have it all painted before the end of the year..... Keyword is HOPE lol
Thanks for the compliment on the paint.
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 03-28-2010, 06:18 PM   #78
jsmithbm
jsmithbm's Avatar
Wire gutters are in and installed, I keep getting this feeling to take the fenders off and inner fedners and just start basting them. LOL I gotta stayed focused..... Still working with the Z-bar linkage. One more cut should do the trick. Headers are mounted except for the left side. I'm want enough room as possible to work with the clutch linkage. Once thats on it will be time to fire it up!!!!
Learning as I go!
Old 04-25-2010, 11:20 PM   #79
jsmithbm
jsmithbm's Avatar
okay ran into a little problem but i think its all fixed now, went to move the motor forward so that the headers would fit and better clearance in general. Had to track down the frame mounts for the motor mounts. They are installed the headers are bolted in. Got a two row radiator installed. ive got an issue with the bolts not fitting the water pump shaft for the pulling i bought course and fine threaded neither work. wiring is all down. the only thing preventing this puppy from firing up is the water pump pulley. still needs a drive shaft but i will have that tomorrow i hope, ive got to search thur about 100 drive shafts to find the right one. Also need to add oil and the filter. i will add photos soon. oh and i broke the alt mounting bolt in the head gonna have to fix that tomorrow too.
Learning as I go!
Old 04-27-2010, 10:18 PM   #80
jsmithbm
jsmithbm's Avatar
i was messin around with the dash bezel and thur some paint on it. Its maroon and silver, but look a little to pink
Learning as I go!
Old 04-28-2010, 12:35 AM   #81
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Looking good Joel, did you get the water pump figured out?
Alan's Classic is offline   Reply With Quote
Old 05-09-2010, 07:37 PM   #82
jsmithbm
jsmithbm's Avatar
So its finally running, i am trying to up load some video. Ive got a few issues i need to finish up before i can drive but i did take it on a few test drives. i need to adjust the shift linkages and put some new gauges on. and thats it!!!
Learning as I go!
Old 05-10-2010, 10:59 PM   #83
jsmithbm
jsmithbm's Avatar
So here is some crappy video of the motor. I took this on my phone at night sorry for the poor quality. Its rather loud to. Still running open headers, i'm going to run some mufflers but not sure which ones just yet.
Learning as I go!
Old 05-10-2010, 11:53 PM   #84
Alan's Classic
Nice progress Joel!!
Old 06-09-2010, 07:17 PM   #85
jsmithbm
jsmithbm's Avatar
So i took the truck for a run down to my parents house this past weekend. Truck did well. I guess the short test drives around town help me settle any concerns i had. Here is the fender i got from Shannon (board member). I welded up the molding hole and applied some body filler. this was my first attempt at welding. I throw down some primer on it today and wrap and store it. I striped the fender down by hand and the other fender i plan on using some metal treatment and priming it as well. My plan is to attack the bed first and work my way forward. So here is another pic of last week at the dirt track. I've been bitten by the race bug too. Another expense hobby!
Learning as I go!
Old 06-09-2010, 07:18 PM   #86
jsmithbm
jsmithbm's Avatar
So i took the truck for a run down to my parents house this past weekend. This was a 120 mile round trip. Truck did well. I guess the short test drives around town help me settle any concerns i had. Here is the fender i got from Shannon (board member). I welded up the molding hole and applied some body filler. this was my first attempt at welding. I throw down some primer on it today and wrap and store it. There are a few runs but hey its my first "big" paint job. I striped the fender down by hand and the other fender i plan on using some metal treatment and priming it as well. My plan is to attack the bed first and work my way forward. So here is another pic of last week at the dirt track. I've been bitten by the race bug too. Another expense hobby!
Learning as I go!
Old 03-06-2011, 10:57 PM   #87
jsmithbm
jsmithbm's Avatar
wow its been almost a year since my last post! Well truck hasnt been driven much. i tore the front sheet metal off and installed the new stuff repaired the core support and jambed the fenders. i need to take a photo of it.
goofin around
why am i sandin everything down to the bare metal????
im not sure, maybe i want to see if there is any filler on there or i want a feeling that the paint is going to have something good under it. This primer is okay i guess, its not to expensive.
Learning as I go!
Old 03-06-2011, 11:36 PM   #88
Alan's Classic
Nic to see you back after it. Now get back to work.
Old 03-07-2011, 12:21 AM   #89
jsmithbm
jsmithbm's Avatar
i gotta have it running and road worthy before Chewing fat!!!!
Learning as I go!
Old 03-07-2011, 11:42 AM   #90
sdailey
The Few, The Proud
sdailey's Avatar
Hey Joel,
Good to see that you're still hanging around. I hope those fenders are working out for you. Look forward to seeing you at our next get together.
Shannon
sdailey is offline   Reply With Quote
Old 03-08-2011, 12:28 AM   #91
jsmithbm
jsmithbm's Avatar
Originally Posted by sdailey View Post
Hey Joel,
Thanks man those puppies are slick as snail....... i have them jambed and installed. i plan on being there for the 2nd annual chew fat and talk smack. I'm hoping that one of these trucks will be running by then. but i dont think it will. i am getting a five speed for the 70.
hows your truck coming along
Learning as I go!
Old 03-08-2011, 12:36 AM   #92
jsmithbm
jsmithbm's Avatar
i picked up some etch primer today for the 58 fenders, went to harbor freight this weekend and picked up some toys. got a siphon sandblaster they were out of the big tank one. I picked up some black diamond sand from TSC for 8 bucks. I hosed down the hood latch. Did pretty good, and made a big ole mess.
Learning as I go!
Old 04-03-2011, 10:39 PM   #93
jsmithbm
jsmithbm's Avatar
got the new air compressor hooked up and running, man what you can get done with steady air! 100 gallon 5 horsepower JennyAir. Got the fenders sanded down for the 58. also used a cutting wheel to cut loose the step side. also sanded the back panel of the cab. heres a few photos.
Learning as I go!
Old 04-04-2011, 12:02 AM   #94
Alan's Classic
nice!!, better hurry up the BBQ is less than a month away
Old 04-04-2011, 10:05 PM   #95
jsmithbm
jsmithbm's Avatar
i dont think i will be driving either one up there but i have another chevy that i will be drivin up!!!! `
Learning as I go!
Old 04-04-2011, 10:21 PM   #96
jsmithbm
jsmithbm's Avatar
i think i am going to go with these lights. whatca think
Learning as I go!
Old 04-04-2011, 10:50 PM   #97
mcbassin
Still Learning
mcbassin's Avatar
I thought I was going to see some paint laid on this project........J/k. Hey are you using the 58 fenders on this project? sorry if I missed it. Keep the pics coming.
Old 04-05-2011, 09:50 PM   #98
jsmithbm
jsmithbm's Avatar
sorry Brother, working two job a death in the family and limited budget will hold ya back.
But to answer your question about the fender no i have another project going on too. I am going to get this one running and shifting right then i am goin to put it on the back burner and try to get the 58 drivable. i will keep the photos coming.
Learning as I go!
Old 04-05-2011, 09:54 PM   #99
Alan's Classic
Looks pretty cool. More info please.
Old 04-05-2011, 09:58 PM   #100
jsmithbm
jsmithbm's Avatar
here ya go....
http://cgi.ebay.com/ebaymotors/6024-...mZ230362213905
Learning as I go!
