Old 03-06-2010, 09:34 AM   #1
Curly86
You want it there when???
Curly86's Avatar
Leaf Spring Question
I have a 86 Silverado swb with a steel flatbed and I pull a 16 ft trailer and 2 other trailers with it and I am fixin to swap out the rear leafs. It now has 3 leafs per side which would be better 5 leafs or 6 leafs what is ya'll opinion? tks
1986 Silverado Flatbed 400 SB with 350 turbo
1997 Ford Explorer with 302 mydrive to work ride
1978 Gmc Midas RV 21ft with 46,000 actual miles
2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow
Big Sandy Survivor 09
Trucks in the Blue Grass Survivor 09
TNCTC
Streetcruzin
Curly86 is offline   Reply With Quote
Old 03-06-2010, 11:45 AM   #2
RuralRoute C-30
RuralRoute C-30's Avatar
Re: Leaf Spring Question
9 is better!
Only 3 and running a 16' trailer? Add as many as you can especially if towing weight with a trailer, in my opinion. Good Luck!
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 03-06-2010, 11:56 AM   #3
bigblock73
yeller
bigblock73's Avatar
If you switch the rear springs out (commonly refereed to as 53" springs) for HD versions, it is likely they will be the longer ones (commonly referred to as the 56" springs)...and you will need to move your rear spring hangers on your truck back to the next set of holes on the frame in order to install them.
bigblock73 is offline   Reply With Quote
Old 03-06-2010, 06:00 PM   #4
Drzronnie
I wish you were closer to me, I have a set of 1 ton rear springs that I am gonna end up scrapping cause nobody will take them.
82 C60
82 C20 (neverending project)
77 Mercedes 300D (gets me to work)
Drzronnie is offline   Reply With Quote
Old 03-07-2010, 12:59 AM   #5
oldschool18
oldschool18's Avatar
I would go 7 or 9.......I think the ones i took off my 1/2 ton 2wd were 7 leaf. see if theres a big truck spring shop around ya, we got one here and they can make new leafs.
oldschool18 is offline   Reply With Quote
