03-06-2010, 11:39 AM | #1 |
65 frame question.
I bought my truck about 2 months ago and the truck has factory powersteering and 5 lug wheels all around. I know the trucks only came 6 lug. how do I tell if this is a later year frame and what year did chevy start factory powersteering and 5 lug patern.
03-06-2010, 01:15 PM | #2 | |
Re: 65 frame question.
Dead give-away should be the front frame horns. 6x-66 front frame horns are physically shaped different vs. post-66 trucks that came w/pwr steering & 5-lugs. Factory 5-lug set-ups started in 71. 5-lug (disc) set-ups & power steering are easy to swap to a 65 6-lug drum brake equipped frame.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-06-2010 at 01:15 PM. |
03-06-2010, 02:26 PM | #3 |
The vin# should be stamped into the frame near the power steering pump. In my case I found that the vin#'s were different on my cab and frame (Cab 64, frame 65).
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
03-06-2010, 09:31 PM | #4 |
ok thanks for the info. I will have to look at the vins I never knew that there was a vin on the frame but it makes sence.
