Old 03-06-2010, 09:36 PM   #1
orangek5
orangek5's Avatar
How Many Bolts to Remove Front Clip?
Need advise or steps in removing a front clip on a 72?
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 03-06-2010, 10:10 PM   #2
No3Fan4Ever
Running on empty
No3Fan4Ever's Avatar
Re: How Many Bolts to Remove Front Clip?
http://67-72chevytrucks.com/vboard/s...d.php?t=194094
hope this helps
We have two rules here at the Rock.
Rule #1: No writing on the walls.
Rule#2: Obey all rules
70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi;
94 Bronco XLT 302, auto;worn out daily driver
No3Fan4Ever is offline   Reply With Quote
Old 03-06-2010, 10:27 PM   #3
72 tigger
72 tigger's Avatar
Here's how I do it - Remove the following: wiper arms,cowl vent,front wheels,inner wheel liners,bumper,radiator, & battery. Then I remove the radiator support bolts (the 2 big ones that go to the frame) & unplug the wiring harness at the firewall (1 bolt in the center needs to be removed then it unplugs). Make sure all other small stuff is unhooked ( alt. wiring, wiper fluid line, etc.) then remove the 6 bolts that hold the fenders to the cab ( 4 at the top & 2 at the bottom). I leave 2 of the uppers in (1 on each side)until I have some help - 1 person to gun out those last 2 bolts (wife works good for that job) & another guy to grab the other fender. We (the 2 guys) then can just pick up the whole doghouse (hood & all) & lift it off the truck. This usually can be done in about an hour using the air gun. Hope this helps!
72 tigger is offline   Reply With Quote
Old 03-07-2010, 12:54 PM   #4
orangek5
orangek5's Avatar
THANKS thats what I needed.
1970 Jimmy 4x4 IL6
1971 SWB 327ci v8
