Old 03-07-2010, 09:03 PM   #1
jyaughn
jyaughn's Avatar
brakes
the passenger front brake is the only one that works. i have pulled all the drums off and checked them and all the wheel cylinders are good and the shoes are good. where would be the next best place to start looking to fix my problem? oh yeah nothing is leaking and the master cylinder has fluid in it
jyaughn is offline   Reply With Quote
Old 03-07-2010, 09:46 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: brakes
You might need to pull the wheel cylinders apart and see what they look like inside. Just because they aren't leaking, doesn't mean they're any good. If the truck has been sitting for a long time, corrosion can built up in the system and cause the pistons to freeze up in the bores. Same is true for the master cylinder. It could be simply a pinched hard line somewhere, but more likely the system needs to be rebuilt and all the lines flushed with new fluid. If you do rebuild everything, be sure to replace all three flex hoses as they can deteriorate and put crud in the system, and they can swell when you apply the brakes reducing pedal pressure (and become a possible safety issue).
Old 03-07-2010, 10:04 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: brakes
Change your rubber hoses.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-07-2010, 10:10 PM   #4
jyaughn
jyaughn's Avatar
Re: brakes
i cant push the pedal down more than about half way so im thinking one of the rubber lines are messed up or something
Old 03-07-2010, 10:26 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
Re: brakes
Did you try adjusting them? Drum brakes need to be adjusted sometimes.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-07-2010, 10:52 PM   #6
jyaughn
jyaughn's Avatar
Re: brakes
yeah they are adjusted right
Old 03-08-2010, 01:07 AM   #7
BMSJaX
BMSJaX's Avatar
Re: brakes
My hoses were clogged shut and my pedal only went half way down. replaced the rubber hoses and tested and blew out all my cylinders So be sure to have some spares ready just in case.
Note: do not use autozone 'Brakeware' brand cylinders, have a high failure rate. Get them from Kragen/O'Reilly.
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 03-08-2010, 06:02 PM   #8
jyaughn
jyaughn's Avatar
Re: brakes
maybe this weekend i will be able to replace them if money allows
