Old 03-08-2010, 01:04 AM   #26
Trip59
Who needs sleep...
Trip59's Avatar
Re: HELP! Does this drop look right?
Originally Posted by CSGAS View Post
This may sound like a stupid idea, too, but did you rock the truck after installing the springs (especially if you have a sway bar installed)?
Because of the geometry and the rates for the springs, the fronts can be held up even by gas-filled shocks...which could add to your headaches if you want. Are you using the same type or family of shocks front and rear?
If you just want to remove some headaches and exercise some muscles, just rock up and down on the front bumper, then see where the front sits. Often we hear a big "klang" as the front gives to where it wants to settle.
Also our longbed trucks will have a different visual look than shortbed trucks with the same drop (and a couple extra pounds on the back, but those springs would have to be awfully soft for that to account for more than a half inch). My longbed has 40-years-of-farmwork rear springs that collapsed almost two coils from sitting while overloaded and my rear shocks are abused but not blown, which may be a closer ballpark to what you started with. I'll stand a T-square up to the wheelwells tomorrow, but I think it looks level (at the frame/bedrail/bodylines) this way.
Most everything else I'd have to offer, would be a repeat of what's already been said--
Thanks CSGAS. I'm going to run it around for a few days before doing anything else to it, but may wind up chopping some height off the front spring to bring it down a bit more (either the stock or the drop ones...)
Originally Posted by 70c10 View Post
Those definitely look like 6" rear springs to me!
They were about 4" shorter than the ones that came out, but a hell of a lot thinner too... I'd be interested in an axle to fender measurement from someone with a 4" and someone with a 6" drop
I actually like the rear, I think I'll be happy with it when I bring the front down. Maybe cut the stock springs and hang on to the drop springs and swap them back in along with some drop spindles to do it right.
Trip
Trip59 is offline   Reply With Quote
Old 03-10-2010, 03:02 PM   #27
CSGAS
optomistic ah-so
CSGAS's Avatar
This may not be of great value directly to you anymore, but when I measured my wheel lips they were both 32" off the ground, front AND rear, with tires about 29" tall all around.
That means with my bad rear springs, I've dropped about 2" in the rear, and that might be where you started as well. It also means that what I thought from the visual "look-and-feel" of the truck, that my frame is level, must not be true yet.
Based on your experience, I think I'm going to shoot for a 2/4 or 2.5/5 inch drop setup when I go shopping. I really like the looks of a 5/7 better but this truck's main purpose will be as a DD/shop truck with rare towing so I have to keep myself in check a lot.
Thanks for taking my advice into consideration, and hopefully members with other drops do chime in, that way this thread could be valuable to a lot of people.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 03-15-2010, 06:26 PM   #28
Trip59
Who needs sleep...
Trip59's Avatar
UPDATE:
Dropped it some more, near what I was hoping for... maybe a touch lower than I wanted.
I cut the stock springs down to try to get what I was after, turns out low enough to hit the bump stops, so the drop springs I felt were too high are going back till I can get drop spindles.
I'm going off my fender measurements, but relative to other's measurements they don't add up because my tire height is only 26" due to the small tires.
Trip
Old 03-15-2010, 07:42 PM   #29
lax54650
Did any of you notice the '58Chevy across the street?
the 58 hit my eyes first nice lookin ride.
i like the way it sits now!!
lax54650 is offline   Reply With Quote
Old 03-15-2010, 08:27 PM   #30
Trip59
Who needs sleep...
Trip59's Avatar
Just measured things and found out it's 4" lower than the 2" drop springs... I think the 2" springs, once they settle, with 2.5 spindles will look about where I want. Now to save my nickles and dimes.
We were just talking about the Impala, once we're done with the major work on the truck and his new front bumper, we may do some work on it. He hasn't driven it twice in the last two years and it's pissing him off.
Trip
Old 03-15-2010, 11:10 PM   #31
kyle fitz
kyle fitz's Avatar
it looks ok to me. 6 inch. new springs need to be broken in. it looks like you might need a c-notch though
kyle fitz is offline   Reply With Quote
Old 03-16-2010, 02:38 PM   #32
Trip59
Who needs sleep...
Trip59's Avatar
I'm racking up quite the list of things to finish it off... next in line
Panhard
2.5 drop spindles & ball joints (PO redid the entire front end, minus ball joints)
then
shock mounts all around and shocks
then... if needed...
C-notch
Somewhere along the way, new shoes all around, those are way too small...
Though it has to get paced out, I'm flat out of money for a while... and also have a ton of stuff I bought to work with too...
Trip
