03-11-2010, 01:27 PM | #1 |
Degreasing
Hi all,
I am replacing the clutch on my K20, and I would really like to clean off the tranny and transfer case before putting them back in. They are covered with the thickest, nastiest grease and crud probably dating back to 1972. The standard engine degreaser and a garden hose is just not cutting it. Any tips? Thanks, Colby. |
03-11-2010, 01:30 PM | #2 |
Under Construction
Re: Degreasing
some oven cleaner from the dollar store.... buy a few cans spray it down heavily, let it set in the sun for a few hours then hose it off with high pressure.... of course scrapping with a putty knife first will help if as thick as you state.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 03-11-2010 at 01:33 PM. |
03-11-2010, 01:34 PM | #3 |
Restoring it $200 at a time...
Re: Degreasing
Take a couple of hours with a plastic putty knife and a wire brush before the liquids come out. Make sure you're on a tarp or gravel though; that crap is like glue on a concrete surface.
Once I had the trans pretty well scraped, I did 409 and a toothbrush to get it ready for paint.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
03-11-2010, 04:21 PM | #4 |
Re: Degreasing
x2 with oven cleaner and a pressure washer.
let the oven cleaner sit on there a bit to penetrate. Simple green works good to finish up with. |
03-11-2010, 05:24 PM | #5 |
Re: Degreasing
I've had much better results with easy off extra strength over cleaner than the cheap off brand stuff. Might buy one can of the good stuff and test it for yourself.
03-11-2010, 08:06 PM | #6 |
Re: Degreasing
maybe a pressure washer
1968 Chevy C10 swb fleetside 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) |
03-11-2010, 08:14 PM | #7 |
One foot in front of the other
Re: Degreasing
Hot water pressure washer is the ticket.
03-11-2010, 08:30 PM | #8 |
Re: Degreasing
I took mine to my favoriate car wash. It was nasty getting up under there and sprayen it but it cleaned it up purty good. Go to a good car wash because some car washes do not have enough presure to p.
69 stepside, 1/2ton, 4X4, 350/350/205 |
03-11-2010, 10:14 PM | #9 |
69 Fleetside
Re: Degreasing
be careful with over cleaner on aluminum...it started to eat at the finish on my starter really quick...but did an amazing job of degreasing and after a couple treatments while leaving it on only 10 minutes at a time and a green scouring pad, my engine bay was super shiney!!
03-11-2010, 11:03 PM | #10 |
2WD Jimmy
Re: Degreasing
Does oven cleaner work better than Gunk?
03-11-2010, 11:10 PM | #11 |
Re: Degreasing
I've had good luck with Oil Eater. You can find it at parts houses and sometimes at Costco. After you scrape the heavy stuff off spray it on, let it set for a few minutes and wash it off at the car wash or sometimes with a hose. It works great for grease spots on cement floors too. Some of the shops up here are using it in their hot tanks instead of caustic as it is biodegradable.
03-11-2010, 11:30 PM | #12 |
Moderator
Re: Degreasing
If you can remove the part, I usually submerge it in a tub full of Purple Power de-greaser and let it soak a few days. Whatever is stuck to the part will come off like butter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
03-11-2010, 11:51 PM | #13 |
Re: Degreasing
I tried everything possible to clean mine and the only thing that worked was scraping the thick crap off and then taking a solvent brush and a little gas in a can cleaned the hell out of it better then anything else I found.
03-12-2010, 12:14 AM | #14 |
HickTown
Re: Degreasing
anyone spray that cheapo oven cleaner on the motor and use it like engine degreaser??
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
03-12-2010, 12:16 AM | #15 |
Man of Mini-Talents
Re: Degreasing
Sand blast it.
03-12-2010, 12:17 AM | #16 |
Re: Degreasing
The brand name over cleaner worked better than gunk for me. The off brand worked about the same as gunk.
03-12-2010, 12:41 AM | #17 |
Re: Degreasing
I've had the best luck with a puddy knife, easy off and a hydorspray/carwash. It works better than engine cleaner. Good luck BBO
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!! |
03-12-2010, 02:02 AM | #18 |
69 Fleetside
Re: Degreasing
03-12-2010, 02:20 AM | #19 |
Re: Degreasing
Castrol Super Clean is good but kinda spendy, So is Simple Green, Oven Cleaner is good, But I gotta agree with the sandblasting as the best method!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
03-13-2010, 01:48 AM | #20 |
Re: Degreasing
Oven cleaner is a great idea, thanks! Someone told me sandblasting is not very effective because the media either bounces off or gets stuck in the grease. True?
03-13-2010, 07:11 AM | #21 |
Re: Degreasing
Putty knife, old wire brush,new wire brush then paint thinner with heavy duty stiff parts cleaner brush, then citrus based soap cleaner and garden hose. Worked for me.
Good luck. |
03-13-2010, 09:01 PM | #22 |
Re: Degreasing
try using a steam cleaning pressure washer.... like a hotsy or hot jenny. they will take just about anything off when it comes to greasy, oily messes.
1965 c/10 swb 1969 c/10 lwb |
03-13-2010, 10:46 PM | #23 |
Grandpa in the rustmobile...
Re: Degreasing
I used combo of pressure washer putty knife screwdriver sandblaster oven cleaner wire brush wire brush on a electric drill
id say HOT water would be great! sandblasting ate thru grease as long as it wasnt really thick for me i only had lil spots here and there....
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-13-2010, 11:01 PM | #24 |
Re: Degreasing
heavy duty degreaser and a pressure cleaner worked for me pretty well...then primered and painted...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
