Old 03-11-2010, 09:17 PM   #1
Del72Chevy
Del72Chevy's Avatar
New Belts Still Squeals
Ive changed the belts on my truck and I still hear a squeal in mid-rpm ranges. This happens while drive and also while stopped with the truck in park. Is it safe to rule out the U-joints since the truck is still squealing in park while pressing the gas?
Del72Chevy is offline   Reply With Quote
Old 03-11-2010, 09:31 PM   #2
glider_6969
Re: New Belts Still Squeals
Have you tried flipping the belt around?
glider_6969 is offline   Reply With Quote
Old 03-11-2010, 09:41 PM   #3
Diablo de la Noche
Diablo de la Noche's Avatar
A long time ago, I had a Buick piece of junk car and the belt was squealing during startup and acceleration. Once it warmed up, it would only squeal during hard acceleration. I changed the belt and still got the squeal sometimes. A mechanic friend of mine told me that sometimes the pulleys get worn out and widen, causing the squeal. If any of your pulleys are older, that might be the issue. Also check to make sure they are all lined up, especially the power steering pump. Mine was out of whack on my 67, the bracket was bent (along with everything else!).
www.coolmoodart.com
Diablo de la Noche is offline   Reply With Quote
Old 03-11-2010, 09:49 PM   #4
Southcity
Southcity's Avatar
What Diablo De La Noche said:
1. Look for worn or broken pulleys or pulley brackets
2. Check for proper Pulley alignment
3. Make sure belt tension is correct
If possible have a friend rev the engine to the point where you hear belt squeal while you do a visual inspection under the hood, this may help to reveal more info about your problem. Just keep the hands and loose clothing clear of moving parts, good luck.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 03-11-2010, 09:57 PM   #5
Del72Chevy
Del72Chevy's Avatar
Thanks for the ideas
Old 03-11-2010, 10:46 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Hold a bar of soap on the belt while it is running. If the belt is the problem, this will soften it up and help.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
