Old 05-08-2003, 09:33 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Anyone Got Specs For Stock CAM In a 70 350???
Does anyone have the specs for the stock cam in the 350 in 1970? What I would like is to have the duration, valve lift, and lobe seperation if possible. I want these numbers for comparison and because i would like to know so i can maybe set it up in Desktop Dyno. Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 05-08-2003, 09:42 PM   #2
70c10
67-72 Addict!
70c10's Avatar
These were the specs I looked up once for my old cam when I pulled it out.
.390 Intake .410 Exhaust
310 Intake duration 329 Exhaust duration
1.5 rockers
I don't remember the lobe seperation, probably 110.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-08-2003, 09:47 PM   #3
HotRod929
HotRod929's Avatar
70c10 - where did you get the #s for the intake and exhaust duration? They seem to be really high. Higher than the performance Comp cams im looking at. Did u mean 210 intake and 229 exhaust? cus that would make a lot more sense. Thanks
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 05-08-2003, 11:27 PM   #4
crazy longhorn
Fabricate till you "puke"
Gm lists the advertised duration different than the cam manufacturers, making it hard to compair. The dur @ .050 on that cam is 195/202....really pretty tame. It should be on 112 lobe sep angles......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-09-2003, 12:09 AM   #5
jhwkns
Registered Cruiser
jhwkns's Avatar
1. Blueprint Hydraulic Lifter Factory Performance Cams -- Meets Memorandum 1-A for Original Applications
Application Series & Grind
Number
Replacement for factory 300 HP 327 cu. in. camshaft. Basic RPM 1000-3200 BluePrinted
3896929
Cam Specifications
Degrees Duration @ .050 Int./Exh. Degrees Advertised Duration Int./Exh. Degree Lobe Separation Open/Close @.050" Cam Lift Int./Exh. Lash Hot Int./Exh. Gross Lift Int./Exh.
195
202 none 112 (10.5) 25.5
37 (15) .000
.000 .390
.410
Crane Cams
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
