Old 03-13-2010, 08:03 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
XKUT Tie Rod Reamer
My K10 steering rod ( drag link ) is not available so I'm going to covert it to the 67-91 double tie rod with sleeve set up. The new tie rods have a larger diameter taper so I'm going to ream the openings to accomadate the new tie rods. They are the same 1 1/2" taper per foot as the old drag link. Willing to share the reamer after I'm finished. The small end of the reamer is 7/16" and the large end is 1".
http://www.xkut-reamers.com/servlet/StoreFront
Old 03-13-2010, 11:37 PM   #2
TR65
TR65's Avatar
Re: XKUT Tie Rod Reamer
Hey Aerotruck,
Just a question. I am interested in why you are reaming the tapers rather than using an adapter sleeve to allow using the small inner tie rods and the large outer tie rods?
I suppose the drag link has plenty of beef to allow the larger tapers?
Good to see your posts again by the way.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-14-2010, 01:19 AM   #3
Captainfab
60-66 Nut
I have one of their reamers and it is a nice quality made in USA piece. I've only used it once so far, but when I needed one I couldn't find one locally.....anywhere....machine shops, auto repair shops, no one had one. Now I have one.
Old 03-14-2010, 07:57 AM   #4
aerotruk63
aerotruk63's Avatar
Talking Re: XKUT Tie Rod Reamer
Originally Posted by TR65 View Post
Hey Aerotruck,
TR
Ok in my small world, I'm crushed that I cannot find a stock replacement aftermarket steering rod GM part# 3854943 1963-66 K10 4WD.. This is the rod that goes from the steering arm to the arm of the drivers side spindle. The 67-91 model truck setup is available so I ordered them in. Now what makes this setup acceptable to me is that there replacement parts for Chevrolet. Childish, silly, brainwashed but I can't bring myself to mixing in from other brands. This new set up adjusts to the same length as the original one piece unit. So when I finish this project, don't come pointing your finger at the steering rod telling everyone that it's the wrong one. I'm in therapy because of this.
Old 03-14-2010, 10:27 PM   #5
TR65
TR65's Avatar
Aerotruck,
OK. I got out the books. I didn't know the K's worked that way. So what you are doing seems perfectly reasonable.
Good to know. I hope to have a 65 K10 someday if Tony doesn't restore them all before I can get one.
TR
1965 C10 SWB Fleet
Two owner
Old 03-14-2010, 10:34 PM   #6
aerotruk63
aerotruk63's Avatar
Get a few, you'll need the parts.
