Old 05-09-2003, 08:48 AM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
power steering gear box
My power steering gear box has developed a leak where the steering shaft enters the gear box. Is this seal and/or bearing replaceable? Isn't there a shade tree mechanic trick to stop these types of leaks with I believe tranny fluid?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-09-2003, 08:51 AM   #2
JimKshortstep4x4
Talking
You will probably need to replace the seal because of the pressure in the box. Seals are available through NAPA and other suppliers. It is not too bad of a job with the box off.
Jim
Old 05-09-2003, 08:53 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks Jim I did not know if the seals were obtainable or replaceable.
Jim
Old 05-09-2003, 09:00 AM   #4
Mike C
Mike C's Avatar
Go ahead and buy the GM overhaul manual. It shows how to rebuild differentials, transmissions, steering boxes, and AC compressors. All of the things that are NOT in other books. I have 2, a 68 model year and a 72 model year. Best books I own...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-09-2003, 09:20 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I had planned on by one from Kingparts a year ago and never did. Looks like I will now. Thanks,
