Old 03-14-2010, 10:08 PM   #1
Trip59
Who needs sleep...
Trip59's Avatar
Can you drive on the stops?
So I cut the stock springs after the 2" drop springs weren't low enough, to get the right profile so I knew what drop spindles to order. Got the look I wanted, but...
Can you drive with the arms sitting on the bumpstops or will it screw something up? Once or twice around town each week for probably a month and a half or so (then I can afford spindles) or should I swap the other springs back in and just deal with a profile I'm not happy with for two months?
OH, and is there anything that can be done with the stock rear panhard bar, I dropped 6" do I have to buy a custom one, or is there some modification that's safe and acceptable to do.
Trip
Trip59 is offline   Reply With Quote
Old 03-14-2010, 10:12 PM   #2
OhOneWS6
OhOneWS6's Avatar
Re: Can you drive on the stops?
For the back I'd buy an adjustable panhard bar. They are not that expensive.
It is going to ride like a buckboard driving on the bump stops. You are basically driving with no suspension. Personally I would not do it. I have heard tale of people tweaking/bending the suspension cross member by frequently bottoming out the bump stops.
OhOneWS6 is offline   Reply With Quote
Old 03-14-2010, 10:14 PM   #3
OhOneWS6
OhOneWS6's Avatar
At the very least I'd cut the bump stops down or replace them with shorter ones so there is some travel.
Old 03-14-2010, 10:25 PM   #4
Trip59
Who needs sleep...
Trip59's Avatar
Thanks!
It's compressing the stops like there's a bit of weight on them...
I wasn't concerned about comfort, I spent most of my riding life on rigid Harleys... I was more concerned with breaking things
All told, the loss of the stock set of springs in trade for knowing the drop spindles I need for sure is a pretty fair trade IMO
Trip
Old 03-14-2010, 11:18 PM   #5
Fitz
Trip
Only if you hit a pothole
Not a very good idea.
Fitz is offline   Reply With Quote
Old 03-14-2010, 11:41 PM   #6
Jeffs70
Jeffs70's Avatar
if your going to keep the truck this low then I would make it easy and drill the spot welds off theme and the stops will pop off there and then cut them shorter then just spot weld them back on that would be your best bet or get shorter ones what ever you prefer easiest for you. but I wouldn't recommend driving on them either.
Jeffs70 is offline   Reply With Quote
Old 03-14-2010, 11:42 PM   #7
Trip59
Who needs sleep...
Trip59's Avatar
That's what I thought... thanks to you both, I'll swap in the too-tall-drop springs back in tomorrow before I go driving.
Ah, that's a relative term... Unless I've not looked in the right place, they're $125+ from what I saw, which is a bit more than I can scrape out of the budget right now (thats why no drop spindles yet).
I have some good ones and I have some bad ones, they're all pretty obvious this one, I wasn't sure about, that's why I asked, very glad I did.
Trip
Old 03-14-2010, 11:52 PM   #8
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Trip
Brothers has them for $63
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-14-2010, 11:59 PM   #9
Trip59
Who needs sleep...
Trip59's Avatar
Ok, I think I missed somehting in all this research before dropping... is the removal of the stop mounts a common thing? will I need to with 2" springs and 2.5" spindles?
Trip
Old 03-15-2010, 12:08 AM   #10
Trip59
Who needs sleep...
Trip59's Avatar
Awesome!!! I'll have to order some next payday.
Hey thanks again for that clutch unit, working like a charm!
Trip
Old 03-15-2010, 02:10 AM   #11
Jeffs70
Jeffs70's Avatar
Trip
no you wont need to remove them with 2" and 2.5" spindles because your spindles are doing half the drop for you, but then 2" is only dropped with your coil springs so you still should have alot of travel for suspension.
the reason we are speaking of removing or shortening your bump stops is the fact you was asking about driving when your truck is sitting on the bump stops and its not a good thing to drive while bottomed out, so best bet to drive that low is to remove the stops or shorten them.
Old 03-15-2010, 03:21 AM   #12
Trip59
Who needs sleep...
Trip59's Avatar
Ah, gotcha...
Not sure I want to remove them then; probably more comfortable just swapping the 2" springs back in for now...it wasn't THAT funny looking
I've gotten pretty good at swapping these, just takes a couple minutes now...
Sort of related, figured I might ask. 6" dropped by spring in the rear, I know I need to do a new panhard and should probably do the shocks, does a 6" have to have a notched frame?
Trip
Old 03-15-2010, 10:28 AM   #13
OhOneWS6
OhOneWS6's Avatar
At the very least you will need shocks and shock relocation brackets for that much drop in the rear. I got my adj panhard from ECE for $59.
Old 03-15-2010, 10:29 AM   #14
gkesseru
gkesseru's Avatar
About the panhard bar, here's what a $6 black iron pipe and a little welding can do to turn it into a full width track bar. I cut the old bar in half and put 3/4" pipe in the middle to extend it. 1/2" pipe is too small and 3/4" is too big so I cut slots in the end of the 3/4 and hammered it closed around the panhard bar, then welded it all together. Made the right end bracket from an old bumper bracket. Also lowered the left end to clear my exhaust. It's not adjustable, but then why would you want to adjust it more than once?
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
