Old 03-14-2010, 10:33 PM   #1
aggieguy713
aggieguy713's Avatar
Clutch and pressure plate question??
I am removing the saginaw three speed and replacing it with a t5 out of an s10. i have to replace the clutch, but my question is, is it possible to remove the clutch by loosening the pressure plate and slipping the clutch out and slipping the new one back in? can i bypass taking the bell housing off?
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 03-14-2010, 10:43 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Clutch and pressure plate question??
It's been a while since I've had one apart but it seems to me that you can, but you have to turn the motor over to get all of the bolts out of the pressure plate. I would recommend turning it over by hand with a small pry bar on the teeth of the flywheel instead of using the starter.
Do you have the adapter plate for the swap?
LockDoc
Leon
Old 03-14-2010, 10:49 PM   #3
aggieguy713
ok. i tried only taking about 4 bolts out, guess i should take the rest out. adapter plate? what do you mean? as far as i know, ive changed the spline, bolt pattern is the same, it should bolt up
Old 03-14-2010, 11:41 PM   #4
aggieguy713
Ttt
Old 03-14-2010, 11:51 PM   #5
LockDoc
LockDoc's Avatar
You mean that you changed the input shaft to a shorter one?
LockDoc
Leon
Old 03-14-2010, 11:56 PM   #6
aggieguy713
Not quite. Just used a shaft out of a t5 that has been behind a 350 previously. So the splines are cut longer, collar is cut a little etc. All the work was done by a local transmission shop.
Old 03-15-2010, 12:16 AM   #7
LockDoc
LockDoc's Avatar
You should be good to go then. I just bought a 9/16" spacer plate for mine.
LockDoc
Leon
Old 03-15-2010, 12:22 AM   #8
aggieguy713
Alright. Thanks for your help, greatley appericated.
Marshall
Old 03-15-2010, 12:57 AM   #9
Mister laugh
Yeh you can just slip the clutch and pressure plate out the inspection hole. I did EXACTLY this this weekend for the EXACT same reason(sag 3spd to t-5 swap).
Mister laugh is offline   Reply With Quote
