Old 03-16-2010, 08:58 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
WTB 72 SBC 1/2 ton Ram horn manifolds
I believe that the factory SBC ram horn manifolds for a 72 1/2 ton 2wd truck angle to the back, not drop straight down (?) This is what I am looking for. Trying to find something cheaper than the $100+/ pair for repros.
WIDESIDE72 is offline   Reply With Quote
Old 03-16-2010, 09:57 PM   #2
68lowburb
68lowburb's Avatar
Re: WTB 72 SBC 1/2 ton Ram horn manifolds
might have a set have to check tommorow and see ,do they both angle back ? thanks jimmy
68lowburb is offline   Reply With Quote
Old 03-17-2010, 07:56 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Not sure if both angle back on a stock set up or not... The engine I am using is a mid 80's and came out of a 71 4x4 and had a set of ram horn's with a stright drop. It seems to me that there would be more restriction with a straight set, since the exhaust pipe will have to have a 90 degree bend.
Old 03-17-2010, 08:00 PM   #4
68lowburb
68lowburb's Avatar
hey ,checked mine today on a 71 350 came out of a pickup both angle towards the back,if its what you need 75 plus shipping ? let me know if you need pic can get it tomorow thanks jimmy
Old 03-17-2010, 08:03 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
Pics would be good. Obviously I would like to have a pair without cracks and decent studs...
Old 03-17-2010, 08:20 PM   #6
68lowburb
68lowburb's Avatar
no cracks that i saw and studs looked good drivers side has heat sheild for riser to, will get you pics tommorow be about the same time thanks jimmy
Old 03-18-2010, 09:57 PM   #7
68lowburb
68lowburb's Avatar
here are the pics ,if interested i could media blast and paint for extra 25 thanks jimmy
Old 03-18-2010, 10:18 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
They look good. How well does paint hold up on these? I usually run them w/ out paint... I think I saw that Eastwood or someone similar had some sort of coating for cast rion manifolds that could be rubbed on the keep them from rusting and looking so nasty...How much to just media blast and ship to Leander TX 78641?
Old 03-18-2010, 10:19 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
How much for the stock valve covers, if they are for sale?
Old 03-18-2010, 10:21 PM   #10
68lowburb
68lowburb's Avatar
Will do 120 plus shipping for everything and i will blast manifolds and covers and paint the covers chevy orange let me know thanks jimmy
Old 03-19-2010, 06:40 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
I don't need the VC's blasted. How much for the manifolds blasted, VC's as is, all shipped to Leander TX 78641?
Steve
Old 03-19-2010, 07:38 PM   #12
68lowburb
68lowburb's Avatar
steve will try and get them boxed tommorow and get shipping quote and give you a total thanks jimmy
Old 03-19-2010, 08:14 PM   #13
OhOneWS6
OhOneWS6's Avatar
Not trying to change your plans but those manifolds without the kink are the more desirable better flowing ones. The ones with the kink are the correct for you 72 though.
OhOneWS6 is offline   Reply With Quote
Old 03-19-2010, 09:25 PM   #14
CSGAS
optomistic ah-so
CSGAS's Avatar
My dad has used the Eastwood stuff on a few manifolds, it needs recoating every few years but it looks good and does prevent rust, does not flake off or have any silly behavior. Applying it with a disposable foam brush seems to work best and you don't have to feel bad about not being able to reuse a brush for anything else.
I'm not sure if protocol allows me to ask, but if neither of you wants those spark plug shields I'll take at least one of the "humped" ones (with the hole for the water temp sensor). the resto places make a set of 4 flat one but not those and it looks like you have two on that engine, sounds like Jimmy you're trying to get rid of the whole thing...if this line of conversation should be moved to a whole new thread I'll be happy to comply.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 03-19-2010, 09:28 PM   #15
68lowburb
68lowburb's Avatar
cs gas if you want them there are yours for the shipping thanks jimmy
Old 03-20-2010, 10:14 AM   #16
WIDESIDE72
WIDESIDE72's Avatar
68lowburb, Does the engine you are pulling the manifolds off of happen to have a timing pointer that is compatible with a 6-3/4" diameter balancer?
Old 03-21-2010, 12:19 AM   #17
68lowburb
68lowburb's Avatar
dont know will check sunday and see ,manifolds and covers 125 shipped as is or 135 for manifolds blasted and shipped thanks jimmy
Old 03-21-2010, 07:46 AM   #18
GMC AMI
GMC AMI's Avatar
Wink Re: WTB 72 SBC 1/2 ton Ram horn manifolds
Here is what I have. PICS did not come out the best because of the sunlight.
Very nice set. Replaced one stud that was missing. No cracks or damage of any kind.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 03-24-2010, 10:23 PM   #19
WIDESIDE72
WIDESIDE72's Avatar
GMC AMI I will pass. I have a trade pending with 68l0wburb.
