Old 03-17-2010, 01:02 PM   #1
shrike
shrike's Avatar
rear end rattle
is driving me nuts! (no pun intended)
I have been hearing this noise since I bought the truck, and I think that it is getting a little worse. Its hard to tell since I drive it every day and if it is getting worse it has been pretty gradual.
It only rattles when I hit a bump or a dip in the road. I dont think its a drivetrain issue because it doesnt matter if I am in gear or not, accelerating/decelerating etc.
I have finally narrowed it down to something on the rear of the truck (by driving over a speed bump).
My initial thought was the tailgate, but im not sure because if I go back and shake the hell out of the tailgate it doesnt make a sound.
The sound itself is kind of a cross between a clunk and a rattle. when I first got the truck I thought the bed was loose, but that is not the case. I have been under the truck many times and have even had the guys at the brake shop look for it but nothing is obviously loose. New shocks on the rear didnt make a difference either.
Any ideas? Anyone had an issue like this?
1970 C10 Fleetside longbed
350/TH350
shrike is offline   Reply With Quote
Old 03-17-2010, 01:06 PM   #2
cdowns
cdowns's Avatar
Re: rear end rattle
panhard bar bushings trailing arm bushings??? exhaust ??
Old 03-17-2010, 01:15 PM   #3
Leviticus
Shake and Bake!
Leviticus's Avatar
Re: rear end rattle
My tailgate rattles a little, but the easiest way to find what it, is grab a beer, lay under the rear of your truck and take a minute to look at everything, shake stuff, bump stuff, rubber mallets help with this (Just be nice).
I was pulling my driveline yesterday and was just taking a minute to look everything over under the rear and found that when they did my exhaust they left the stock hanger bracket in the rubber mount and it was twisted in a way the when you bumped it it would rattle (Old Rubber).
Good luck.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 03-17-2010, 01:24 PM   #4
shrike
shrike's Avatar
Re: rear end rattle
Thanks for the replies!
I dont think its the exhaust. I had new mufflers put on after I bought the truck and while I wont say that the exhaust system is rattle free, I know it isnt loose enough to make a noise this loud
Will I be able to move the trailing arms enough to tell if the bushings are bad? Or is it something I'll be able to see? I wonder if I should jack up the frame so the rear end is hanging free and see if I can locate it that way
350/TH350
Old 03-17-2010, 06:39 PM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: rear end rattle
check the shock bushings and the swaybar bushings and mounts (if you have a swaybar). My dad used to have a ranger that would rattle like crazy on rough roads, turned out to be a missing sway bar bushing....never did fix it though.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-17-2010, 08:36 PM   #6
bigguy69
dazed and confused
bigguy69's Avatar
Re: rear end rattle
i have seen them when the panhard bar bushing is wore out they make that noise.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 03-17-2010, 08:45 PM   #7
hayhauler71
hayhauler71's Avatar
Re: rear end rattle
My moneys on the panhard bar being noisy with the rest of the guys, this problem is as common as rusted rockers and cab corners.
hayhauler71 is offline   Reply With Quote
Old 03-17-2010, 10:21 PM   #8
Bullseye54
Re: rear end rattle
Do you have a receiver hitch on the truck? Several times I've had a cluncking/rattle & its been the hitch or pin.........Bob
1967 C20 Custom - 396/TH400
1968 GMC short step-350/M21
Bullseye54 is offline   Reply With Quote
