![]() Join Date: Aug 2009
Suspension Part Needed
I need the passenger side bracket that mounts to the frame that the shock bolts too.
![]() My truck is a 1972 C10 fleetside, with leaf springs
Blayne Last edited by thepunisher; 03-18-2010 at 12:12 PM. |
![]() Join Date: Nov 2003
Re: Suspension Part Needed
I have a 68 GMC leaf spring setup and converting to trailing arms. I will be grinding these off soon. I can sell these to you but make sure they fit.
How about $35 shipped? Thanks, JE
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 |
Can you send be the height and depth? If that matches close to mine I'll take em.
Blayne |
72ChevyStep
![]() Join Date: Jun 2009
I just measured:
4.5" height of the inside frame rail where this shock mount fits. The top two rivets were 3 1/8" apart ctr to ctr. JE
![]() Join Date: Sep 2006
let me know if you dont get it ,have several thanks jimmy
I need to modify my request, originally I thought I needed only one of the brackets, I actually need both. Both shocks must have been flipped behind the differential. Most likely because of the truck being used as a fith wheel trailer. I would assume the mounting bolt for the shock is replaceable but just in case I would like the bolt as well if they are in good shape.
steinepstein the brackets from your truck are the same size so those will work. So far I think you have asked $35 shipped for both is that right?
Blayne |
OH yea, that's for both.
JE
72ChevyStep
I appologize if I broke site educate steinepstein was the first to reply to my want post. I was uncertain of fitment so I PMed tabarcus since his truck was closer in year to mine. With the dimmensions steinepstein posted his will fit.
Blayne |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
I believe site etiquette with a WTB ad is that you can choose to buy from who ever you want too. No order of post applies.
MODS: Feel free to correct me if I am wrong.
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 Last edited by wancosc356; 03-24-2010 at 05:04 PM. Reason: Added info. |
