Old 03-18-2010, 08:16 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
need BRAKE help fast!!
ok heres a pic of what I have my truck has crap for breaks.....I have 2 thoughts
is my proptioning valve in correctly
are my brake lines crossed
my truck is a 70 drum drum truck
what happen is my line that cross's the X memember got a crack it drained the back of the master so I'm not sure whats going on ....I have pulled allt he drums and pads and drums are new
I need to attack this in the morning I need my truck tomorrow afternoon
Thanx
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-18-2010, 08:18 PM   #2
Hottrucks
Hottrucks's Avatar
Re: need BRAKE help fast!!
I have been looking at some other pics of brake set ups and it seem like most of the pics I see the wire for the light is on the top??
Old 03-18-2010, 08:55 PM   #3
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Here is my old setup and it worked great untill the booster went bad. My light wire plugs in the bottom. Hope this helps you.Name:  old booster.jpg
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 03-18-2010, 08:59 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
can you get all the drums to bleed? If so make sure the rear brakes are properly adjusted, If you can pull the drum off the back with little force, you may need new adjusters, the back should have some drag to it.
If you cant get the front (or the one that bled back to the master) to bleed you may have to bench bleed the master to get the air out of it.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-18-2010, 09:03 PM   #5
Hottrucks
Hottrucks's Avatar
hey camaro nut your set up looks like mine but I think my proportioning vavle is backwards??? and which line goes to the rear......????
Old 03-18-2010, 09:21 PM   #6
Hottrucks
Hottrucks's Avatar
smitty everything is new or cleaned..bleeding isn't an issue....I'm just not sure things are routed in the right directions??
Old 03-18-2010, 09:27 PM   #7
Chevydude56
Chevydude56's Avatar
Were the brakes OK until the line leaked?
You need to replace/repair the line and bleed all the brakes.
Any air in the system will give you bad brakes.
You don't have a proportioning valve , you have a distribution block.
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 03-18-2010, 09:32 PM   #8
Hottrucks
Hottrucks's Avatar
the brake where...ok....I was never impressed with them ..I just added the booster set up and they didn't seem any better..I was thinking the booster is bad....
what I am sure of it that all the lines are new bleeding isn't an issue pad and drums are new and no leaks at the wheel cylinders
Old 03-18-2010, 10:50 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
your 'block' 'valve' etc is upside down compared to my disc setup......
John
1999 Toyota Tacoma 4x4
Old 03-19-2010, 12:42 AM   #10
Chevydude56
I have a drum brake '67 suburban and I am not impressed with the brakes either . I will be converting to front disc or 4 wheel disc.
Here is a picture of mine , I think the booster was added at some point.
second picture , closeup of distribution block, switch on bottom
Third pic is a drum brake without a booster, switch on bottom
Forth picture is disc brake truck with prop valve, switch on top.
1964 Chevy II wagon
1967 GTO
1978 Chevy Van 30
Old 03-19-2010, 02:01 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Your distibution block is backwards.
In your pic the back of the block needs to face the front of the truck.
Both front lines are towards the front of the truck.
(front bowl of M/C and front brake lines)
Both rear lines are towards the rear of the truck.
(rear bowl of M/C and rear brake lines)
Keith
Convert to disc brakes.
Old 03-19-2010, 07:00 AM   #12
Hottrucks
Hottrucks's Avatar
well I'm going to flip the block around and blead the lines again....Disc brakes are only a few months away then I'll be looking for a disc vavle
I'll keep you posted
Old 03-19-2010, 07:10 AM   #13
truckdude239
truckdude239's Avatar
on ym 71 the block vavkle is turned witht eh wire going up
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-19-2010, 07:39 AM   #14
Diablo de la Noche
Diablo de la Noche's Avatar
I saw somewhere, on Speed TV or something, that when you put in a booster you need to change the pedal and rod. Something about a different size rod needed to operate the booster properly. If you didn't change that out when you added the booster, that might be why you don't get the full power from them.
www.coolmoodart.com
Diablo de la Noche is offline   Reply With Quote
Old 03-19-2010, 07:58 AM   #15
Hottrucks
Hottrucks's Avatar
did the swap it was very easy..I swapped every thing including the rod....I'll be done in a coule hours and see what happens
Old 03-19-2010, 08:05 AM   #16
Longhorn321
Size Matters
Longhorn321's Avatar
Is your concern that a front line was leaking and the rear resevoir was the one that went dry? That is normal I think. You get more pressure on the front that way.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 03-19-2010, 08:26 AM   #17
Hottrucks
Hottrucks's Avatar
Yep and that the "valve" /"block" is in correctly...I want more presure to tthe front it makefor better wheel stands!!!!
Old 03-19-2010, 08:45 AM   #18
Longhorn321
Size Matters
Here is a pic of my '69 C20 Longhorn with Drum/Drum. It looks exactly like yours.
...WOOOO HOOOO!!!!
Old 03-19-2010, 08:56 AM   #19
Sinister
Between Trucks...
Sinister's Avatar
If your master cylinder went dry you might need to bleed it again. You can do this on the truck, just unhook the lines and hook up the bleeding kit. Might want to tape or lightly clamp the bleed kit lines so they don't fall out of the reservoirs.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-19-2010, 09:05 AM   #20
Chevydude56
There should be two holes in the brake pedal arm for the rod. For power brakes the lower hole should be used. Upper hole for non power brakes
1964 Chevy II wagon
1967 GTO
1978 Chevy Van 30
Old 03-19-2010, 09:15 AM   #21
Beuford
Beuford's Avatar
I have a `70 drum n drum setup that I'm changing to front disc. My wire is on the bottom of the prop valve and since it was a 1 owner truck I believe that is how mine came from the factory.
Beuford is offline   Reply With Quote
Old 03-20-2010, 06:31 PM   #22
Hottrucks
Hottrucks's Avatar
ok I blead everying out did some swapping and I think that they are as good as they are going to get I bought a use Booster from a board memeber and I'm pretty sure its FUBAR...but I will say they are 50% better and I think one more bleeding will help a tad more..
than Guys for the pics it helped alot..mine now looks like long horns and chevy dudes I believe that to bet he correct set up
Old 03-20-2010, 10:08 PM   #23
71 super
71 super's Avatar
distribution block is backwards fix that and you should have better brakes.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-21-2010, 05:57 PM   #24
69BB396
69BB396's Avatar
I would agree. If you check your photo with Camaro-Nut's, the dist.block should have the mount bolt at the back. My '69 BB Chevy was the same.
RW
(Photo coming)
69BB396 is offline   Reply With Quote
Old 03-21-2010, 06:26 PM   #25
69BB396
69BB396's Avatar
Here's a picture of it...
