Old 03-20-2010, 08:27 AM   #1
hotrod_991
hotrod_991's Avatar
window roller upper posts
ok I know the title makes me sound like a 5th grader but really dont know what they are called but i need new ones. it the pice that the window cranks go into with all the grooves and the clip. as you can see in the pics i dont have them cause they are stipped bad and the back yard window cranks aka vicegrips have not helped the situation so its time for replacements. were can i find them and do i have to replace the hole lift assembly or get just new posts? Thanks
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 03-20-2010, 10:26 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: window roller upper posts
I have had the gears inside behind the crank handle post strip before and was able to drill out the rivets on another car (ten years newer than mine) and bolt the piece onto my 66 El Camino. I think they are pretty widely used by GM so as long as the handle type is similar to yours if will probably work. Just take some depth measurements of yours before you hit the wrecking yard. Bring a cordless drill and you can just buy the small piece you need instead of the whole window regulator assembly.
You can convert to the older metal window crank handles that rarely strip out while you are at it. I cut my stock posts down so the older handles would fit but you could just install the older posts and matching handles. Check out my build thread for pics of what I am talking about.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
