Old 03-20-2010, 04:32 PM   #1
skhurst18
skhurst18's Avatar
Smog Pump Removal
Hello Everyone! I am removing the smog pump from my 5.7l. It is not hooked up and not required in my state of residence. Can anyone tell me what to do about the openings in the exhaust manifolds and the sensor to the smog pump? I thought about replacing the manifolds with ones that do not have the smog access. Any suggestions would be greatly appreciated.
skhurst18 is offline   Reply With Quote
Old 03-20-2010, 07:56 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: Smog Pump Removal
What year is the truck?
You have 3 options on the exhaust
1 go to home depot and buy plugs to cap off the ports.
2 buy a set of headers.
3 buy a stock set of non air injection manifolds.
Id go with #2.........Actually i did! lol
Im trying to think of what sensor your talkin about i dont remember there being one.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 03-20-2010, 09:13 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
#2 is the coolest option..
my truck at one point intime had smog during the rebuild i removed everything related to it, pump was allready gone, then i also did headers. which now just is ... well it's awesome! hahaha
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-21-2010, 03:36 AM   #4
spinem
haha, ford guys...
I believe he has the same smog i do, it is not "AIR INJECTION" instead is it "RECLAIM".
the tube off the headers/manifolds is introduced into the air pump, egr, carb.
this is what i did:
2.00 usd
No tubes comming off headers at flange
spinem is offline   Reply With Quote
Old 03-21-2010, 12:46 PM   #5
dammitmitchell
the pollock
hey those are some sexy valve covers where did you get them?
Army vet 02-08
Old 03-21-2010, 07:49 PM   #6
spinem
haha, ford guys...
thank you sir, 1989 napa special order!
Old 04-13-2010, 05:35 AM   #7
skhurst18
skhurst18's Avatar
Sorry it took me so long to reply. Been working ot and falling behind on my honey do list. My truck is a 87 silverado r10 lwb 5.7l tbi. I have recently come across another 5.7l tbi from a 92 chevy 4x4. The manifolds on this one doesn't have the smog ports on them. Think I will swap them out. Here are some pics of the ones with the smog.
Old 04-13-2010, 05:40 AM   #8
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
is the sensor you talking about the O2 Senser? has mostly a 4 wire plug
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 04-13-2010, 10:54 AM   #9
Slofarmtruck
As far as the smog tubes go, cut the metal tube off from the nut that threads into the manifold. Remove said nut from manifold and weld the tube hole shut. Re-install the now closed threaded nut.
Slofarmtruck is offline   Reply With Quote
Old 04-13-2010, 02:26 PM   #10
spinem
haha, ford guys...
x2
Old 04-13-2010, 05:18 PM   #11
Slofarmtruck
You could even weld the nuts shut while still attached to the manifolds in the vehicle if you felt like it. Would make the job a little harder but is possible. Than remove any associated components that the tubes are attached to.
Old 04-13-2010, 07:44 PM   #12
83GMCK2500
Are you kidding me? That is a lot of effort when you can go buy 8 (3/8", I think) NPT threaded plugs and screw them in. I pulled my maniolds, unscrewed the smog tubes, knocked the insert tubes out of the holes, chased the threads with a 3/8" NPT bottom tap, put some anti-sieze on my allen-head plugs, installed, and reinstalled the manifolds. Looks like attached pic but stainless steel. You don't have to remove the manifolds, I did because I hate standing on my head working on things.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 04-14-2010, 05:59 AM   #13
skhurst18
skhurst18's Avatar
Thanks for the info. The plug idea sounds less time consuming. I'll let you guys know how it goes.
Old 04-14-2010, 06:05 AM   #14
S10Fan
Old Heap Driver
............and find a suitable sized box to keep and store all the smog stuff you remove. Needing all that $%#! to meet "new" smog regulations one day will make that box a welcome sight. LOL.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-14-2010, 10:54 AM   #15
Slofarmtruck
I didn't have to remove the manifolds to weld the nut shut. Took me all of 10 minutes in my garage to complete the job. I was just too lazy to go to the hardware store to find a plug. Either way will work. Plus his truck only has 1 smog tube coming off each manifold like mine did. SO you only need to perform this twice.
Old 04-14-2010, 12:44 PM   #16
83GMCK2500
Exclamation Re: Smog Pump Removal
More power to you if you got it welded up that fast. It would have taken me 15 minutes to get the welder and everything out to to do it that way. At the time the shop was not yet organized very well, we had just moved.
EDIT: Oh wow, that one does only have one tube on it. When did GM go to that style? Mine had 4 smaller ones and some were very testy to unscrew.
Devin
New Daily, the '96
Old 04-14-2010, 05:16 PM   #17
Slofarmtruck
I know my early 90's truck had 8 A.I.R. tubes going into the exhaust manifold which was just easer to remove and plug as long as you could get the tubes out of the manifold. At that point swapping in a set of non emissions headers was my next step for simplifying the removal of emissions components. I was very pleased to see my 86 305 only had the 2 A.I.R tubes! Great info in the thread though!! Thanks 83GMCK2500 for your feedback as I am sure it will help others in the future as well.
Old 04-26-2010, 10:20 PM   #18
skhurst18
skhurst18's Avatar
The plug idea worked great. I had the existing bolts tapped and purchased the plugs for $1.50. Thanks for the great idea. This will hold me until I can purchase some headers and new exhaust system. Here are some pics of the plugs.
