Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-21-2010, 07:57 PM   #1
NtheFamily
NtheFamily's Avatar
92 s10 temp fluctuating
Okay, I have a '92 s10 that I bought last year with 139,000 miles on the 4.3. I have installed a new radiator, new upper and lower rad. hoses, new water pump, new thermostat and new oil pressure sending unit.
Few questions:
1) When I drive it somewhere, the temperature gauge will climb to about 210 or a little higher then go down to about 195 - 200 during the first several minutes or approximately first 20 miles of driving it (been doing this since I bought it even before I put the new stuff on). I put a 195 thermostat in it. Why does the temperature fluctuate so much? Will this harm the engine since the temperature does go down?
2) I replaced the oil pressure sending unit since the original one was leaking. When it is firsted cranked up and I drive it for 20 miles or so, all is fine (50 - 60 lbs on oil pressure gauge), but when I stop at a red light it drops to about 16 lbs. Is this normal lbs. of oil pressure at a stop? If not, what is normal?
3) Can you by new 4.3 motors for it from Chevrolet that is an easy swap and if so, has anyone priced them ?
Other than that the truck runs great, gets great gas mileage (from what I'm used to getting from my '85 4x4...which is 9 mph) and is not banged up.
Thanks for all and any ifomation.
NtheFamily is offline   Reply With Quote
Old 03-21-2010, 08:22 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 92 s10 temp fluctuating
mine does the same thing with the oil its cause its a higher mileage motor. AS long as i have over 10 PSI oil at idle im happy
the temp sending unit may be bad or the thermostat could be bad. Ive had them bad brand new
you can get a crate GM motor cheaper than other rebuilts and if youre handy its pretty easy to swap get yourself a haynes manual first
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-22-2010, 06:35 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
bad stat will cause the temp deal. it is waiting too long to start opening and having trouble regulating the temp. this is assuming you have all the air bled out. we use nothing but the superstats from Stant/Gates.
have you verified the oil pressure with a known mechanical gauge? I have a customer with a 92 Astro (same engine) with 247,000 miles and it holds 30 PSI at hot idle/stop light.
IIRC GM sells a Goodwrench engine for your application for ~ $2100
68C15 is offline   Reply With Quote
Old 03-22-2010, 11:54 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I dont think you have a temp issue at all. Takes a bit for the stat to open and then the cool water flows thru the engine and cools it off. It then stabilizes. Thats how all my trucks do it, too.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-23-2010, 08:59 PM   #5
NtheFamily
NtheFamily's Avatar
Thanks guys for all the info. Kind of makes me feel a little better.
{have you verified the oil pressure with a known mechanical gauge? I have a customer with a 92 Astro (same engine) with 247,000 miles and it holds 30 PSI at hot idle/stop light.} no i have not verified it with a mech. gauge 68C15, i guess i might need to check on that.
{this is assuming you have all the air bled out} ....What is the proper way of bleeding the air out of the system? I believe i need to try this.
Thanks again to all.
Old 03-23-2010, 10:08 PM   #6
old Rusty C10
if you go tot he 73/87 section there is a post by Ruralroute c30 there which deals with bleeding his system which is pretty well like yours...
Bob
I hate cancer!!
Old 03-25-2010, 09:48 AM   #7
NtheFamily
NtheFamily's Avatar
Thanks ol rusty C10.
