03-22-2010, 07:00 AM | #126 | |
Re: Project Charity Case
I think I am going to buy some 6" springs for the rear first.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
04-03-2010, 04:31 PM | #127 |
SUPERscrapMAN
Truck looks great. I like the rake much better than the loaded pics. If you are going ot use it as a truck the rake might be a better choice to keep from dragging the bumper on the pavement epically if you tow a car behind it.
Christine 1987 Chevy S10 2.8l 5 speed 600k miles! still chugging along - wifes ride Old Smokey 1990 Chevy K1500 Suburban 6.2L Diesel - Banks sidewinder The WarBeast 1994 Chevy Suburban K1500 - Semi retired at 400K miles The BLueOx 1994 Chevy Suburban. K2500 454 Used on a daily basis. |
05-01-2010, 11:19 AM | #128 | |
Adam B
Thanks, Adam |
05-01-2010, 12:50 PM | #129 | |
You can purchase these wheels from Summit Racing, Jegs, and any of the major wheel shops. I hope this helps!
07-01-2010, 04:12 PM | #130 |
Whats your width on the front and rear wheels? Truck looks good, I love it. I was thinking of going with 17x7 on front and 17x8 on back. What do you think?
07-01-2010, 04:52 PM | #131 |
These trucks will accommodate decently wide wheel without any modifications. I have 8" wide wheels in the front and 9.5" in the rear with no rubbing. There is room to fit a 10" wheel in the rear as long as the back spacing is correct. Personally, I like the widths that are on my truck now. Since the last pictures were taken, I have dropped the rear another inch, so I have a 4.5" drop in the front and 6" drop in the rear.
07-01-2010, 05:12 PM | #132 | |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
07-01-2010, 06:21 PM | #133 | |
Tot Roddin'
Glad to see you made it back home safely.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-01-2010, 08:41 PM | #134 |
Hmmmm...pictures are going to be difficult at this time. Give me a few more days and I will see what I can come up with. Deal? Ha, ha...
07-01-2010, 10:50 PM | #135 |
Grandpa in the rustmobile...
cmon man wheres the pictures?!?!?!?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-01-2010, 11:12 PM | #136 |
Junk Yartist
subscribing
07-02-2010, 07:53 AM | #137 |
Here is a teaser for you. I will get better pictures soon.
07-02-2010, 06:51 PM | #138 |
ah come on man, dont do that to us! from the angle i am looking at the drop looks awesome!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
07-02-2010, 09:19 PM | #139 |
Still Learning
Truck looks great!
07-09-2010, 12:49 AM | #140 |
Great build-up...really good work on the rust repair, too!! IMHO, trucks need rake!!
08-17-2010, 01:15 AM | #141 |
love the look of your pick up! I sold my 89 a few years back and have not yet replaced it with a daily driver. Ive had a soft spot for these forever! My lady has been trying to convince me to get one going. I have a 72 that is screaming to be put back on the road. not enough time in a day! lol I have a 48 on an s-10 chassis, but its not quite scratching the itch for a 72!
08-21-2010, 06:52 PM | #142 |
I have a little update on the truck for those that are interested.
A couple of you asked about pictures of the truck after I swapped the 5" rear springs for 6" springs. So, here it is...this is 4.5" drop in the front and 6" drop in the rear. I personally like how it looks. As you can see, it still has a little rake, but nothing like it did with the 5" springs. I also have been doing some necessary engine work this summer. Earlier this year, I noticed that the engine was using A LOT of oil (2 quarts in 300 miles), but the compression was good and it only smoked on start up. I suspected that the valve guides were worn. I also had a slight hesitation at cruising speed that I could not fix, so I decided to pull the heads. I found two valve seats that were sunken due to the unleaded fuel. I had been running lead additive, but the damage was likely already done when I bought the truck. My plan was to put the engine back as cheaply as possible, so I took the heads to a local shop to get them rebuilt. The owner talked me in to finding a better casting, because the 307 heads do not have great flow characteristics and have tiny intake valves (1.7"). So, I found a set of rebuilt 305 heads. They were from a early 80's Camaro and the seller had already installed 1.94 intake valves, Z28 springs, new valve seats, etc... I realized that the stock camshaft was not going to let these heads breathe like they should, so I chose a camshaft that had good low end torque to match the heads. I also threw in a new timing chain set, gaskets and a fresh coat of paint. Here is what the engine looked like today right after I broke in the new cam: The engine seems to run much better now. I still have a few bugs to work out, but overall I am happy. On a side note, half way through the head replacement, a friend called me because he received a 1970 LWB on trade for a car he was selling. I looked at it and it has a decent sounding 327. It has a fairly radical camshaft, headers, single plane intake, double hump heads and a holley carb. I pulled a valve cover off and it was obvious there were some new parts inside the engine. The previous owner said the engine was rebuilt, but had no paperwork. He also thought it was a 350, but the casting numbers confirm that it started life as a 327. I bought the truck and may swap this engine over into my truck. I need to think about this one some more.
08-21-2010, 07:10 PM | #143 |
VA72C10
engine looks great! Sounds like you have a tough decision on swapping out the other but either way you now have two nice engines!
Oh, and the 6" springs complete the drop perfectly! Love it!
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 08-21-2010 at 07:11 PM. |
08-21-2010, 10:31 PM | #144 |
Tot Roddin'
Much better running the 4.5/6" drop IMO... man that looks good!
Diggin' the engine mods as well.
08-22-2010, 11:13 AM | #145 |
Restoration Virgin!
Nice work Jesse....love the 4.5/ 6 drop....I think it looks awesome on our trucks!!!.....let's ssee some pictures of that 70LWB!!!....That see thru passenger rocker is AWESOME
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
08-22-2010, 04:30 PM | #146 |
Geoff, I didn't want to post pictures, because I knew you would be jealous over the wheels that are on the truck. Honestly, the only good thing on the truck is the engine, doors, hood, a few interior parts. The cab would be good for patch panels. I haven't decided if I am going to part it out or just swap engines and sell it complete. Here are some pics. Bring on the envy!!!!
08-22-2010, 05:59 PM | #147 |
swap it lol nice truck, looks like a lot of good pannels still!
08-22-2010, 08:25 PM | #148 |
Restoration Virgin!
There you go making me all jealous and crap....dang I want those wheels!!!
Glass looks good in the cab...I'd be interested in it if you part! Are those helper springs
08-22-2010, 09:00 PM | #149 | |
The glass (factory tinted) is in good shape. I will let you know if I part it out. Those springs are a factory option (RPO G60). Have you ever seen anything like that? It was new to me. The truck came from Nebraska and it appears that it was a service truck of some type. It is hard to see in the first picture, but there is a huge "N" painted on the hood and smaller ones on the doors. I think it stands for "Nice Wheels".
08-23-2010, 08:37 AM | #150 | |
Restoration Virgin!
Was it a big red "N"???....That is a University of Nebraska Cornhusker truck....surprised it isn't red!!!...Ironically, my Dad actually played football there, so my family grew up as Husker fans!!!....That's awesome!!!
