Old 03-23-2010, 08:11 PM   #1
mmcderm
Drop spindles and wide front wheels
I have a '69 C10 SWB and I have used 2 1/2" drop spindles from LMC to lower the front. I want to buy 17" wheels from Wheel Vintiques, but I am not sure if there will be any interference between the wheel and the steering linkage. the wheels I want are 17" with a 4.5" backspacing. Does anyone out there have experience with this? Thanks.
mmcderm is offline   Reply With Quote
Old 03-23-2010, 09:02 PM   #2
Jeffs70
Jeffs70's Avatar
Re: Drop spindles and wide front wheels
I am not sure if this would help you at all but, I just installed my new disc brake setup with drop spindles made by McGaughy's purchased from http://www.classicheartbeat.com/67-7...suspension.htm
I am also running with 17" wheels and I have not one problem with them hitting any thing.
Jeffs70 is offline   Reply With Quote
Old 03-23-2010, 09:17 PM   #3
mmcderm
What is the backspacing on your front wheels? From what I understand, anything over 4" will cause interference problems.
My sickness includes:
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 03-23-2010, 09:39 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No, it's not going to interfere. You can run 4.5 inch backspacing on a 15 inch wheels with drop spindles and it still clears. The 17s will clear by even more.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-23-2010, 10:01 PM   #5
HuggerCST
HuggerCST's Avatar
No clearance problems here with 2.5" spindles, 17x8s and a 5" backspace.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-23-2010, 10:02 PM   #6
mmcderm
I bent a piece of tig wire to match the diameter and backspacing and it looks like I might have some interference around the tie rod depending on the inside diameter of the rim. Do you have any pictures showing that there is no interference? Does it matter what type of brakes you have or are there any other contributing factors to this issue. I would just like make sure before I order the wheels. I would hate to have to pay to ship the wheels back. Thanks.
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 03-23-2010, 10:04 PM   #7
mmcderm
Would it be too much to ask if you could send me a photo of the tie rod inside the wheel so I can get an idea of how tight the clearance is. Thanks.
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 03-23-2010, 10:19 PM   #8
Tx Firefighter
If you search my past posts, I have built about 6 trucks since I've been on this board, all of them with drop spindles. I'm kind of a picture whore so there's plenty of images to see. My current truck has drop spindles and 15x8 with 4.25 backspace and no issues with lots of clearance to spare.
Old 03-23-2010, 10:23 PM   #9
Tx Firefighter
15x8 with 4.5 backspace. 2.5 inch drop spindles and 2 inch drop springs...
Old 03-23-2010, 10:25 PM   #10
Tx Firefighter
Same truck, same suspension with 17x8 wheels and 5 inch backspacing...
Old 03-23-2010, 10:26 PM   #11
Tx Firefighter
Nothing cut, nothing rubbing, no grinding needed...
Old 03-23-2010, 10:51 PM   #12
HuggerCST
HuggerCST's Avatar
We have the same taste in wheels Tx. I'm thinking about trying a set of 17" Halibrands ar Cragers. Here are a couple of pics mmcderm. One thing about mine though, and it may or may not make a difference, mine has late '70s/early '80s style drop spindles. (1 inch wide rotor)
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 03-24-2010, 08:37 AM   #13
mmcderm
Thanks everybody for the info. I'll be comparing the photos to my spindles when I get home from work, and if everything looks ok, I'll be ordering my wheels. Thanks again for all of your help.
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 03-24-2010, 09:42 AM   #14
JJanzen
JJanzen's Avatar
Wynne,
What size/brand tires are you running on both the front and rear? Thanks.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 03-24-2010, 09:58 AM   #15
HuggerCST
HuggerCST's Avatar
Originally Posted by JJanzen View Post
Wynne,
I've got Fusion ZRI 255/50/17s on the front and Falken Ziex 275/50/17 on the rear. The tread is very similar on these two brands.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 03-24-2010, 11:32 AM   #16
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Check out this tool. http://www.wheelworksinc.com/mountmate.html
With it, you can check out tire diameters, wheel offset, etc. I don't know of any tire shop in my area that has one, but it would sure be nice to have if you were in the tire/wheel business.
Member Nr. 2770
Old 03-24-2010, 08:04 PM   #17
mmcderm
Does anyone know if there is any difference between the 71-72 style spindles and the late 70s spindles?
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 03-24-2010, 08:14 PM   #18
darthwall
I know you can use the later spindles with the later brakes and put them on the 67-72 arms but you have to use the ball joints and tie rods
darthwall is offline   Reply With Quote
Old 03-24-2010, 10:06 PM   #19
HuggerCST
HuggerCST's Avatar
Actually only one ball joint is different, and I think it's the upper, but I'm not positive. I've never compared the two spindles, but I don't think you will have any trouble. Txfirefighter didn't.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 05-26-2010, 08:56 PM   #20
mmcderm
The wheels came in and everything fits. Thanks, everybody, for the help.
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 05-27-2010, 06:27 PM   #21
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
What size and backspacing did you end up getting?
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 05-27-2010, 07:57 PM   #22
mmcderm
They are supposed to be 17"x8" with 4.5" backspacing, but I haven't confirmed the backspacing.
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 05-27-2010, 09:03 PM   #23
Bennett68C10
Bennett68C10's Avatar
Please post pics of these wheels when you get the tires mounted and on the truck, i'm very interested thanks.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-27-2010, 10:39 PM   #24
mmcderm
I hate to keep you waiting, so I will go ahead and tell you that it is going to be a while before I get tires. I have to get rid of the old wheels and tires so I can afford them.
'66 Mustang
'69 C10
'76 CJ5
'07 Mustang GT-CS
Old 05-27-2010, 10:47 PM   #25
Bennett68C10
No problem my truck is on the very slow road of being built as well
Keith
66 Suburban
IG: bennett68c10
my sickness includes:
