#2401 |
I'm just glad to be here!
Re: Project Vitamin C-10
Getting the hinge on w/o scratching the paint is the easy part. Putting the spring on and not damaging the paint with what I want to know.
Did you adjust the hinge location so that the hood closes correctly? If so, did that scratch any of the paint around the hinge on the inner fender?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#2402 | ||
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
#2403 |
Under Construction
Nice Work Alan!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#2404 |
Slots go on anything!
Keep it up Alan. You might have a second career as a hand model.
1974 Jimmy- 5.3/4L80e/NP241 |
#2405 |
283 Drama Queen
![]() Join Date: Dec 2004
![]() Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#2406 |
#2407 |
![]() Join Date: Jan 2009
Great progress Alan and I'm looking forward to the final pictures on that fuel tank set up....
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion |
#2408 | ||
![]() ![]() Quote:
![]() Quote:
![]() No progress on my side of the fence tonight. I went over to help Shannon set his cab on his frame. Still in jury duty. ![]() Shannon and I did get the 55 running last night. Just have to fine tune the timing and carb adjustment.
Alan
#2409 |
Wow, great work!
'01 GMC Sierra ~ daily '64 Chevrolet El Camino ~ project '80 C-10: 5.7L/custom ~ My Baby! - sold - European Union -> Germany -> Bavaria -> Franconia -> Nuermberg ![]() |
#2410 |
Sunburst C10!!!
3 more pages!!!!
your almost to 100 Alan
Gage 1967 C10 Shortbed Stepside |
#2411 |
Looking good ALAN cant wait to see the finished product.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#2412 |
HOW long until spring??
![]() Join Date: Mar 2009
Hi Alan, Again Nice work.
Reading your thread again starting at post 2370, during the mock-up of the fuel filler door, What year and model donated the green fuel door? Was that a random choice or is a perfect fit of the body lines Also what O.D. is the filler pipe off the tank? I bought a RCI 17 gallon cell from summit and will be modifying the fill pipe to turn out as I would like to have a outside fill door. Your metal skills are outstanding , I will have to recruit a body man relative . Thanks-- bubba
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#2413 | |
![]() Who would have thought that? Had no idea that I would even get one page when I signed onto the forum. Step by step. Quote:
No progress tonight working on the 55.
Alan
#2414 | |
The Few, The Proud
![]() Join Date: Jun 2007
Shannon |
#2415 |
Thanks Alan and Shannon, Carry on
#2416 |
Thanks, Man!!
Will do. ![]() Shannon and I got the rear brakes done last night. Had to redo the Rt side again, because I failed to read the instructions that reminded me the right hand thread went on the left and the left hand thread self adjuster went on the right drum. I had two new ones, but they were both right hand thread, that's why it didn't even cross my mind.
Alan
#2417 | |
![]() Join Date: Nov 2009
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel |
#2418 |
Alan, I love digital cameras and take lots of pictures before I tear stuff like brakes apart then I can look to see how they go back together if they will be apart for some time. Then I read the manual .
I found on my truck's rear brakes the shoes were installed wrong by P.O. and the shorter shoe was in the rear position on the passenger side.
#2419 | ||
Call it beginners luck or what ever, but I got the fan shroud made today. I couldn't have ask for anything better. As we all know I have limited experience with custom fabrication. To me this was complex due to exact measurements. I don't know if I would have the same luck if I made another. Here are the steps I took. The sheet of aluminum ![]() What I had in mind. ![]() The layout ![]() ![]() The piece cut out and corners notched. ![]() The first set of bends ![]() I used these vice grips to tweak a couple corners that didn't bend to a true 90* ![]() Ran out of time today. This is where it is at now. Still need to make the top and bottom caps and cut the hole for the fan then test fit. Hope it clears the engine. ![]() ![]()
Alan
#2420 |
Nice work Alan!
Glad to see you are still chipping away at it ![]()
#2421 | |
Daring to be Different
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#2422 |
The Few, The Proud
Looking good Alan.
Shannon |
#2423 |
Shloooooong bed member #2
Dang that looks good Alan.....super work.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
#2424 |
Member of the longbed union.
Looks really good Alan. go ahead and bend me on up too, just to see if you can do it again. I bet you cant. Haha.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#2425 |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
