NV4500 swap in a 76 K10
I've got a 76 K10 that currently has a 350 w/ an SM465 and an NP205 10 spline transfer case w/ the 8 bolt pattern. I am wanting to put a NV4500 in place of the SM465 and keep the 205 t-case, and i already know that i need an adapter plate to pair up the nv4500 and the np205, but what im not sure about is if i can use the stock bellhousing from the nv4500 on my 76 350, or if i will have to get the aftermarket bellhousing for the nv4500 to bolt up to 86 and earlier small block chevys? If anybody has any info about this would appreciate the input.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Re: NV4500 swap in a 76 K10
Cant use the 465 bell on any 4500. You will need the bell that goes with that tranny. Also don't need an adapter, just need to open up 2 of the holes and notch the tranny side of the flange to clear the shift rail on the 205...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Ok. What about adapting the output shaft of the 4500 to the 10 spline on the 205?
![]() Join Date: Feb 2007
Swap the input shaft of the transfercase to a 32 spline gear. That will mate to your output shaft on the trans and will be a stouter set up too, eliminates the coupler.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
i forgot, you will need to machine the housing at the input bearing to accept the larger input bearing that goes with the 32 spline gear. If the machining and parts chasing gets to be too much look for a late 80's - '92 NP205 with the round pattern 6 bolt pattern, this will have the larger input bearing already installed. This will also let you mount the tc directly to the tail of the trans eliminating the adapter too.
Bellhousing: do you want to run your mechanical clutch linkage or convert to hydraulic? AA sells a custom bellhousing that allows you to use your existing mechanical, or you can use the bellhousing that would come with the NV4500 and switch to a hydraulic setup. -steve
Well I am wanting to switch to a hydrualic clutch so I will have no issues using the 4500 bellhousing. And thanks for the info about the t cases. I will consider just getting a different 205
I have the round pattern 205, but shipping might be a deal breaker.
I don't think it's hard to open the case for the bigger bearing, or to get the retainer or input itself.
Are the 6 bolt 205's still gear driven?
yup! look for them behind TH400s from '89-'92. might have been in them a couple years earlier than '89, i forget.
Dont forget the square body styles were dropped after 1987 in the half tons series. You are looking for the 1 tons which remained until '92 in the solid axle square body style. -steve
1t cab & chassis through`89,Duallys through`88,and Crewcabs through`91.
yeah im definitly interested in a 6 bolt 205, but shipping from ny to co would be outrageous
#12 | |
'77 K20 LWB 454, NV4500, NP205, 4.10's rollin on 33's passin everything but a gas station. ![]() |
