Old 03-27-2010, 11:18 PM   #1
factorystock
factorystock's Avatar
For 292 fans
"The truck man's truck engine" with "traditional virtues". The engine was a fleet favorite at UPS in tough stop and go delivery work before they went diesel in the 90's.
factorystock is offline   Reply With Quote
Old 03-27-2010, 11:33 PM   #2
'72customdeluxe
Re: For 292 fans
Wow, 280 ft/lbs is pretty good nice. If my truck came with a 292 i wouldn't swap it out
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 03-28-2010, 06:07 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: For 292 fans
The 292 will taken out of the C60 I've bought and be going into the K10 project. When I was researching modifying my 250, the word was to treat the 292 like a Big Block.
Old 03-28-2010, 06:55 AM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: For 292 fans
"It's lighter..."
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 03-28-2010, 07:55 AM   #5
aerotruk63
aerotruk63's Avatar
Re: For 292 fans
Better pic's below
Old 03-28-2010, 08:08 AM   #6
Shaky
Shaky's Avatar
Re: For 292 fans
Aerotruk - those images are great. Do you have them larger size or better quality? I'd love to be able to look those over...
Old 03-28-2010, 08:14 AM   #7
aerotruk63
aerotruk63's Avatar
Re: For 292 fans
Try this or print them.
http://picasaweb.google.com/normanme...eat=directlink
Old 03-28-2010, 08:18 AM   #8
Shaky
Shaky's Avatar
Re: For 292 fans
Thanks! I'm glad somebody posted these, but they're a little tough to read. I'll have to try and track down the original document.
Old 03-28-2010, 08:36 AM   #9
aerotruk63
aerotruk63's Avatar
Re: For 292 fans
Old 03-28-2010, 08:13 PM   #10
factorystock
Re: For 292 fans
283=3" stroke,327= 3 1/4" stroke, 396=3 3/4" stroke,454=4.0" stroke. 292=4 1/8" stroke. The 292 is the original "stroker engine".
Old 03-28-2010, 08:29 PM   #11
aerotruk63
aerotruk63's Avatar
Re: For 292 fans
Switch the head from a 194 it's like a closed chamber head and you will up the compression ratio. Pertronix for the distributer for original look with a hotter spark. Iridium plugs. 8mm wires, Remove the oil bath guts and find a K&N filter with an adapter if necessary and install it in the stock air cleaner assembly. What else without machining or loosing originality?
Old 03-29-2010, 03:12 PM   #12
Shaky
Shaky's Avatar
Re: For 292 fans
Don't expect to spin it too much. Long stroke = high piston velocity for a given rpm = large loads on main bearings, rod bearings, and rod bolts.
Old 03-30-2010, 08:15 PM   #13
Born Lucky
Re: For 292 fans
Thanks for the info..
I just purchased my first 1966 C20 Chevy truck and my first 292.
So far (after power wash) the engine is showing the leaks.
I have a rear main, pan, distributor, oil leaks.
The carb needs rebuilt and the exhaust manifolds leak.
Not but for a original engine!
I am working on making it a daily driver.
Born Lucky is offline   Reply With Quote
Old 03-30-2010, 08:23 PM   #14
aerotruk63
aerotruk63's Avatar
Re: For 292 fans
And you smiling while you wrote it. Have fun on this site. Don`t be shy to ask. Were really all about the pictures! Got a few?
