Old 03-28-2010, 10:27 PM   #1
Kmart2352
Kmart2352's Avatar
Cutting a coil
I would like to know the procedure for cutting a 1/2 of coil. I would like to know the whole thing, from how to get the spring out and to the assembly.
Thank you
87 2wd GMC Sierra Classic.
86 4wd GMC Sierra Classic.
95 2wd GMC Sierra.
96 2wd Chevrolet S-10.
Kmart2352 is offline   Reply With Quote
Old 03-28-2010, 10:35 PM   #2
diponyou
diponyou's Avatar
Re: Cutting a coil
well bro its not too bad of a job.
i posted a reply about cutting the springs while there still in.
but if thats not an option then
get yourself some spring clamps
i believe you can do it by only removing the bottom joint on the spindle
pull spring cut and replace everything.
if you just did the spindles it shouldnt be difficult for you at all.
but spring clamps are going to be necessary either way.
go to your local auto parts store and rent them.
then post pics
diponyou is offline   Reply With Quote
Old 03-28-2010, 10:45 PM   #3
fiddy9apache
fiddy9apache's Avatar
Re: Cutting a coil
no need for spring clamps, just when the bottom ball joint breaks loose lower the jack slowly letting the spring and arm drop letting all the tension off the spring. then cut your spring with a cut off wheel, never use fire, put jack back under a arm and put spring in place and jack arm up and put the spindle back on the lower ball joint, tighten you ball joint nut and install tie rod back on spindle.
fiddy9apache is offline   Reply With Quote
Old 03-28-2010, 10:45 PM   #4
Kmart2352
Kmart2352's Avatar
Re: Cutting a coil
alrite thank you I am going to have to give it a shot next weekend or some weekend
95 2wd GMC Sierra.
Old 03-28-2010, 11:00 PM   #5
Kmart2352
Kmart2352's Avatar
Re: Cutting a coil
how much do you cut off the coil?
95 2wd GMC Sierra.
