Old 03-30-2010, 11:55 AM   #1
tjsblazer
tjsblazer's Avatar
Largest tire/wheels on a stock ride height 72 K5
I have a 72 Blazer 4wd with a 4 inch susp lift. I want to remove it and return to the stock ride height. What is the largest rim/tire combo I can use. I'm thinking about using 15" Chev truck rally rims. I'm guessing that 32" x 11.5 on 15's would be the largest. What are you stock susp guys running?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 03-30-2010, 04:12 PM   #2
SeventyOne
Re: Largest tire/wheels on a stock ride height 72 K5
When I bought my Blazer it had 33x12.50x15 (pretty sure they were 15x10 wagon wheels with maybe 3.5" BS) and they worked fine on stock worn out suspension.
Backspacing and how worn out the springs will play into what you can run.
I would stick with the 32's to be safe.
SeventyOne is offline   Reply With Quote
Old 03-30-2010, 04:15 PM   #3
lks dcvn
lks dcvn's Avatar
I think the blue blazer I am building has 33s on it right now [but I would have to check to be certain] with stock suspension.
lks dcvn is offline   Reply With Quote
Old 03-30-2010, 04:47 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've always heard that 33's will fit on a stock ride, but keep in mind, the actual tire diameter may be different than the size. I've seen 35" that are closer to 33" tall and some closer to 37" tall.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-30-2010, 05:21 PM   #5
Blazer1970
Blazer1970's Avatar
You can run 33 X 12.50s as long as you don't twist up the suspension on the trails. 33s will rub with a 4 inch lift if you flex the suspension close to maximum.
Blazer1970 is offline   Reply With Quote
Old 03-30-2010, 06:02 PM   #6
tjsblazer
tjsblazer's Avatar
This Blazer won't be offroading, at least not bad enough to worry about twisting. Do GM truck rally rims come in a variety of offsets or are they all the same?
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 03-30-2010, 06:49 PM   #7
MT300RUM
MT300RUM's Avatar
Ive got 33,12.50s on mine right now and it's all stock, havent had it rub yet..
What are you going to do with the old lift??? All spring? or spring & block?
MT300RUM is offline   Reply With Quote
Old 03-30-2010, 09:04 PM   #8
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
33x12.50 here also, stock suspension.
Jason
Cap'n Hook is offline   Reply With Quote
Old 03-31-2010, 10:36 AM   #9
Steven B
Steven B's Avatar
33/12.50 on the Jimmy. I don't do any off roading either.
70 Jimmy 4x4
71 GMC 2500
Too bad stupidity isn't painful
Steven B is offline   Reply With Quote
Old 03-31-2010, 01:03 PM   #10
Firebirdjones
I run 33 x 10.5's (BFG all terrains) on ours with a 15 x 8 aluminum wheel and it's just fine with stock ride height on original suspension.
We do some mild trail riding around the mountains here, but I generally don't care to take the truck anywhere it might bottom out or scrape, so we stick to the mild stuff. It's 99% a daily driver though.
Never had an issue with rubbing.
Firebirdjones is offline   Reply With Quote
Old 03-31-2010, 01:54 PM   #11
skidder111
skidder111's Avatar
Some time ago I ran 31x10.50 on stock rallys with a saggy old suspension on mine. There was no issue. With a 4" lift now, it has 305 -70/16. BTW, where are you located? Cheers.
skidder111 is offline   Reply With Quote
Old 03-31-2010, 10:46 PM   #12
tjsblazer
tjsblazer's Avatar
Lift is front springs with rear blocks. I'm not going to use them anymore so ill be selling but it will be a couple of months before I get them out. If your interested I can keep it in mind.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 03-31-2010, 10:50 PM   #13
tjsblazer
tjsblazer's Avatar
Way east of you. I'm in southwestern Ontario.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 03-31-2010, 10:55 PM   #14
tjsblazer
tjsblazer's Avatar
So it looks like quite a few people are running 33's on stock suspension. I'm looking for pics of stock suspension rides running GM truck rally rims. If anyone could post that would be great. Cheers.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-01-2010, 04:24 AM   #15
OARNGESI
OARNGESI's Avatar
Heres mine 33x12.5x15 stock suspension with rallies
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-01-2010, 08:51 AM   #16
tjsblazer
tjsblazer's Avatar
Looks great! Are the rims 8 or 10 inch wide? Like the color too, is that the factory bronze?
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-01-2010, 09:38 AM   #17
Firebirdjones
Here are a couple of mine, out on the trail and at home. Not factory ralley's but same or similar offsets.
I actually plan to locate a set of factory steel wheels (dog dish hubcap style) in 15 x 8's and paint them white for a different look. Hope this helps.
Old 04-01-2010, 09:38 AM   #18
OARNGESI
OARNGESI's Avatar
There 8s the color is copperhead pearl
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 04-01-2010, 09:42 PM   #19
BLUE THUNDER
BLUE THUNDER's Avatar
Not rallys, but here's mine before the lift.
BLUE THUNDER is offline   Reply With Quote
Old 04-19-2016, 11:12 PM   #20
cwilkie
Chance
cwilkie's Avatar
How do you remove a 4 inch lift! Just buy stock leaf springs and shocks? I have a 1972 blazer that is lift which I want to return to stoc height. Any help is appreciated.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
