Old 03-30-2010, 07:59 PM   #1
bigunde
Rusty Rockerfeller
72 Chevy one ton single rear with disc brakes??
about to pick up a rolling frame from a 72 chevy 4x4 truck. it is 8 lug and has the one ton style rear end with the front loaded chunk and also has disc brakes.it is 8 lug and im getting the 4 speed and transfer case as well.is this a one ton or 3/4 ton? ill probably try and sell it but just want to figure out what it is. thanks
bigunde is offline   Reply With Quote
Old 03-30-2010, 10:19 PM   #2
Re: 72 Chevy one ton single rear with disc brakes??
Well,there were no factory K/30s.It could be a C/30 Napco conversion.Most likely a K/20 and some HO52s had the pre-load set on them.Only the brakes and bearings vary between HO52 and HO72...other than the pre-load.
Old 03-30-2010, 11:02 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
If you decide to sell it, shoot me a PM please!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-31-2010, 12:55 AM   #4
justcuz
justcuz's Avatar
Rear disc brakes were probably onstalled as a cheaper alternative to buying drums for these rear ends. Discs are all later model stuff with 14 bolt brackets.
justcuz is offline   Reply With Quote
Old 03-31-2010, 07:55 AM   #5
bigunde
Rusty Rockerfeller
The front has the disc brakes, not the rear. Sorry about that
Old 04-01-2010, 05:45 AM   #6
Blazer1970
Blazer1970's Avatar
It is a 3/4 ton. Front discs were standard starting in '71.
Blazer1970 is offline   Reply With Quote
