03-31-2010, 04:49 PM | #1 |
Driveshaft question
Have replaced factory Powerglide out of my 1966 1/2 ton with a newer model powerglide. The shaft on the new transmission is fine splined and longer the the original with less splines . would there be a correct length drive shaft to switch with my original to fit? Maybe soneone who has done this before will have a answer for me . second thought this is a 2 piece driveshaft and would like to stay with 2 piece design
03-31-2010, 08:11 PM | #2 |
"Where were you in '62?"
Re: Driveshaft question
I think a few guys on here has done this. If you don't get a response for a while on here...try The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums: Engine & Drivetrain ((((Transmission Specs )))) http://67-72chevytrucks.com/vboard/s...d.php?t=390542 There were two primary versions of the Powerglide. The Powerglide transmission introduced in 1950 had a cast iron case and is known as the "Cast Iron Powerglide". The "Cast Iron Powerglide" and was used until 1963, when it was revamped as "Aluminum Powerglide" where its case and several of its other parts were made of aluminum. The Aluminum Powerglide was used from 1962 until it was replaced with the Turbo-Hydramatic series of transmission in the early 1970s. The Aluminum Powerglide is still used today as a racing transmission of choice by many racers mainly for the fact that it only shifts once, and for its extreme durability. Power Glide 25 23/64" 16 5/16" 20 9/16" 3 3/4" 19" Short shaft Power Glide 27 9/16" 16 5/16" 20 9/16" 3 3/4" 19" Long shaft
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-31-2010 at 08:12 PM. |
04-01-2010, 08:34 AM | #3 |
Thanks for the tip.......Anybody else?
04-14-2010, 09:41 AM | #4 |
Thought I would let you know, while researching all the possibilities I came across, a standard drive shaft out of a 67 turdo 350 was an exact fit for my long shaft Pg.................no more looking.................back on the road!!!!!!
