Old 03-31-2010, 10:46 PM   #1
robgrin
robgrin's Avatar
gas pedal linkage
Whats everybody using for gas pedal linkage. I bought a v8 conversion linkage that is for 1953-59 chevy truck but its not even close. I have a 58 cab with a 350 small block and a 4 barrel carb.
robgrin is offline   Reply With Quote
Old 03-31-2010, 11:21 PM   #2
OrrieG
OrrieG's Avatar
Re: gas pedal linkage
I've used and will continue to use the stock V-8 linkage, simple lever and rod. Some guys use mid 70's truck pedal assemblies, they use a pull cable, pedal assy bolts to the firewall from inside. I prefer the rod so if for some reason both return springs fail I can put my toe under the rod and push the throttle closed, hard to do with a tension cable or Toyotas.
Old 04-01-2010, 01:26 AM   #3
drivea55
drivea55's Avatar
agreed! ditto... it works and the latter is a nice thing to know
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 04-01-2010, 06:14 PM   #4
Wrenchbender Ret
Often when you buy the kit new it is assembled the wrong way. Very confusing. Take it apart & you might be able to see how it goes. If not someone might post a photo of it. They have always worked good for me.
Wrenchbender Ret is offline   Reply With Quote
Old 04-01-2010, 09:19 PM   #5
Rude Dude
Rude Dude's Avatar
This what I used there are generic on egay site cheaper than this
http://www.lokar.com/product-descrip...ttlepedals.htm
Rude Dude is offline   Reply With Quote
