04-01-2010, 05:54 PM | #1 |
Single or Double??
I should probably know, But i don't, Ive owned my 72 K5 for 5 years and it's only had the one top, so how can you tell if it is a single wall or double wall top? i never even knew there were different tops till i joined this site,
04-01-2010, 07:14 PM | #2 |
Re: Single or Double??
Easiest way to tell is to look at the bolts that hold the top onto the bedsides.
If the bolts go down into the bedside you have a single wall. If the bolts go up into the top from under the bed railing you have a double wall. Another way to tell is if you have lights mounted to your top on near the rear side window. If you have a 72 and it's the stock top, it's likely a single wall. |
04-01-2010, 07:37 PM | #3 |
Its Topless Season!!!!
Here are some pics for comparison
Double wall Single wall |
04-01-2010, 08:53 PM | #4 |
Thanks you guys are great, now if anybody asks i can tell them i have a single wall top, and act like i know something, Thanks again for the info..
p.s clos69, what are the long stainless pieces laying in the back on the lower pic? i have a couple of these lying around myself |
04-01-2010, 09:08 PM | #5 |
Not trying to hijack the thread but................is one type better than the other? Quieter??
Thanks, tbruz |
04-01-2010, 09:11 PM | #6 |
A lot of people like the single wall best because the bolts go down into the bed sides. If you have interior side panels in the cargo area you can install and remove the top without removing your side panels.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-01-2010, 09:21 PM | #7 |
04-01-2010, 09:52 PM | #8 |
People also argue that single walls are noticeably lighter.......I doubt that based on their construction but I've never lifted a single off a truck before.
Quieter.....haven't heard that comparison before but I would think a dbl would be quieter if at all. |
04-01-2010, 09:57 PM | #9 |
If I didn't have side panels or never planned to take the top off, I would go with a double wall, just because I think it looks better on the inside.
04-01-2010, 10:36 PM | #10 |
SKINNY TIRES RULE!
Actually, the easiest way to tell the difference is if it has dome lights.
No Dome lights = double wall dome lights = singlewall
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-02-2010, 01:14 AM | #11 |
Or the plug for the lights behind the driver seat if you can't see the lights in some angles... |
04-02-2010, 09:48 AM | #12 |
2WD Jimmy
Im not trying to be funny here, but mine was quietest with the top off.
04-06-2010, 07:49 AM | #13 |
Those are my carpet edge strips
04-08-2010, 10:11 PM | #14 |
Active Member
The biggest issue i have seen with double wall tops is the warpage. Single wall tops don't seem to warp as bad if at all.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
