Old 04-01-2010, 10:40 PM   #26
SCOTI
SCOTI's Avatar
Re: McGaughy Big Brake kit
Originally Posted by 87chevy.com View Post
do you have any pictures? and the 13.4 rotors are off of a c6? what did you do for a hub?
Answered above....
I have some 13.4" rotors, dual piston PBR calipers, & KORE3's billet hub (both w/car & truck pattern).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-01-2010, 10:42 PM   #27
SCOTI
SCOTI's Avatar
A few more . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-02-2010, 04:11 AM   #28
c10seconds
c10seconds's Avatar
Originally Posted by SCOTI View Post
A few more . . ....
Is the hub meant for the HD (1.25)spindles? And does it come pre-drilled for both lug pattern?
c10seconds is offline   Reply With Quote
Old 04-02-2010, 08:30 AM   #29
aggie91
I'm just glad to be here!
aggie91's Avatar
Scoti - That set up looks good. I assume that is a 20" Coy wheel in the pictures. Are the holes that the bracket bolts to the original holes in the spindle?
When I called they have a hub for both the HD and LD brakes. The HD hub is not on the web site yet, but the one for the LD hub is the same hub as the one for the GM Tall Spindle HD for the Impalla SS.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-02-2010, 08:37 AM   #30
aggie91
aggie91's Avatar
The rotors are the 340 mm C6 Z51 Front Rotors. Looks like they have added the 5 on 5 pattern and opened up the center hub hole.
Karl
The LST Challenge:
Old 04-02-2010, 12:34 PM   #31
SCOTI
SCOTI's Avatar
Yes.
Yes, a 20x8.5" Coy C5 & yes those are the OE splash shield holes drilled out & tapped.
Correct again. The rotors are aftermarket (DBA) & not just GM/OE units.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-02-2010, 10:20 PM   #32
aggie91
aggie91's Avatar
I looked a little more on the Kore3's site and now I am REALLY interested in doing this mod to the front of my '98 daily driver. I will most likely hold off on doing this to my 65 for a while. I am going to use 15" ralley wheels for now.
Looks like I have to save my lunch money...
Karl
The LST Challenge:
Old 04-03-2010, 06:02 PM   #33
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I modified a stock spindle like shown above and I'm going to cut the rotor portion off of the stock front brake rotor and turn it into a hub.. I'm going to try and put dodge front brakes on this spindle. The front rotor of the dodge has the same register as the fronts 3.08... im sure I can get it to work, but for 50 bucks for a rotor/caliper.. its worth a try. If sucessfull it will match the rears, plus I can grab the master and prop valve and call it a day.. probally wont be that simple but.. all else fails, just grab the hub from Tobin and a set of rotors.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-03-2010, 07:21 PM   #34
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Scoti that is a really nice looking kit. What is the application on the caliper? Wondering if Wilwood makes a replacement...
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-03-2010, 07:37 PM   #35
87chevy.com
usually kore3 sells either regular corvette or zo6 calipers.
Old 04-05-2010, 09:19 AM   #36
aggie91
aggie91's Avatar
It is a Corvette front caliper with Kore3's logo machined into it. Look on Kore3's web site, I think that they have other Vette calipers and colors also.
Karl
The LST Challenge:
