Old 04-02-2010, 10:23 AM   #1576
nlped
nlped's Avatar
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
And, now there ordered , along with an Auburn posi that I found for a smokin' deal and all the bearings and seals
I'll be askin' you lots of questions now that I have made the decision to put the 5.3 in the Blazer
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-02-2010, 10:32 AM   #1577
bigdnew
Never Satisfied
bigdnew's Avatar
Where did you find the set up.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 04-02-2010, 10:39 AM   #1578
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Is the a/c done yet
LOL, funny you ask. The parts house just called to say that the condenser I ordered is in. I have all the major parts I need other than o-rings and the manifold seals. I can probably get those tomorrow.
Ask away!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-02-2010, 10:52 AM   #1579
nlped
nlped's Avatar
Hey BigDNew, I shot you a pm so I'm not hijacking Bob's thread...too much
Carter
Old 04-02-2010, 10:55 AM   #1580
nlped
nlped's Avatar
Wouldn't the stock condensor work? Or was it "time" for one?
Carter
Old 04-02-2010, 10:57 AM   #1581
bigdnew
Never Satisfied
bigdnew's Avatar
ditto, sorry bob.
Old 04-02-2010, 11:06 AM   #1582
glock35ipsc
No problem guys!
I wanted to replace the condenser and the accumulator with new ones, 1] because of switching from R12 to R134A it is easier to just swap them than to clean them both of the old refrigerant and oil, and 2] the OEM condenser was a little ratty looking and was tweaked here and there. The accumulator had already been replace some time ago with a R134A compatible one, but it was only $30-something for a new one so I figured WTH.
Bob
Old 04-02-2010, 11:20 AM   #1583
nlped
nlped's Avatar
Gotcha! And I always replace the accumulator if I open the system...it's will get contaminated with a quickness.
Carter
Old 04-02-2010, 01:34 PM   #1584
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by glock35ipsc View Post
No problem guys!
Bob,
Is it the R12 oil or residue that kills the direct swap out to r134? I think the 86 has been changed to r134 not sure. I know the "descicant dryer" should be changed any time the system is cracked, but not sure about the accumulator.?
I thought about just changing the dryer and orings and doing the r134 conversion, I assume since I don't know what is in there I should just change everything? You know how much that will cost on the oem parts not LS? Remember, this is a super low buck project.here
Old 04-02-2010, 02:19 PM   #1585
glock35ipsc
The receiver drier and accumulator is the same thing basically.
If you blow out the system you should be OK with just the accumulator. A new one was $30-something, and the condenser was $110.
Bob
Old 04-02-2010, 02:37 PM   #1586
mcbassin
Still Learning
mcbassin's Avatar
Okay thanks, I was thinking the accumulator is the coil that the fan blows the cold air across. My bad.
Old 04-02-2010, 02:41 PM   #1587
glock35ipsc
That one is the evaporator.
Bob
Old 04-03-2010, 01:44 AM   #1588
ERASER5
ERASER5's Avatar
No problem guys!
There will be absolutely no R12 left after a proper vacuum. The accumulator does need to be R134A compatible due the desiccant bags. R134A will generally destroy the R12 bags. The old oil (3G mineral oil) does not need to be removed. The old oil will settle in the low points and in the compressor and not affect the system any more. A little 3G oil will keep the compressor a little cooler.
[QUOTE=glock35ipsc;3896883]The receiver drier and accumulator is the same thing basically.
Not even close. The are the opposite of one another. Both do have desiccant bags. The receiver only lets high pressure liquid pass and the accumulator only lets low pressure gas pass. The receiver system uses a TXV system and the accumulator uses an orifice system.
Replacing the desiccant any time you open the system is completely unnecessary unless you leave the system open for many hours, like all night with high humidity. A good vacuum pump will be able to pull out any moisture after a few hours. Vacuum is of utmost importance when servicing a refrigerant system.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-03-2010, 02:18 AM   #1589
JCampbell
*Subscribed*
JCampbell is offline   Reply With Quote
Old 04-03-2010, 10:02 AM   #1590
glock35ipsc
So where is the receiver on my 85?
Bob
Old 04-03-2010, 04:19 PM   #1591
fpjr0
fpjr0's Avatar
Originally Posted by djracer View Post
Which tach do you have? Part number please? Most autometers have loops that you cut to select 4,6 or 8 cylinders.
As far as the resistor I wouldn't think the resistor being 1/2 watt in stead of 1/4 watt would not matter.
I dont know the part # however
just in case some of you run into the same problem when installing a tach. I did the resistor trick, and it works... just the needle kind of vibrates but works good,, here is a pic.... sorry about the constant threadjacking Bob gonna start my own so I can stop jacking threads lol
ONCE YOU GO LS, YOU NEVER WANT LESS!!
fpjr0 is offline   Reply With Quote
Old 04-03-2010, 06:55 PM   #1592
djracer
djracer's Avatar
this should be the tach you have but you have to use a paper clip to flip switches.
http://www.autometer.com/productPDF/...sh%20tach).pdf
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-03-2010, 07:11 PM   #1593
glock35ipsc
Originally Posted by buckshot305 View Post
Bob, did you ever start on the write-up/FAQ? I understand why if you haven't; it's hard to go back over so many details and organize it after you've finished a project. Their is a wealth of information in your thread, it's just hard to find specific info. I had to go back to page 1 and speed read through, bookmarking things as I went. Also, I must have missed it, but why are you replacing the rubber FI hose with SS? Did it start leaking?
Thanks,
Travis
I'm slowly working on it. Really busy at work and home.
As for the fuel line, I'm replacing the line from the filter to the furl rail. It's about 4' or so, and I'm jut not all that comfortable with that much rubber. So I'm just replacing that stretch with braided. I should have done that from the beginning, but I didn't.
Got a late start today after having brunch with my wife's side of the family, then gathering a couple more needed parts. So far I have the AC compressor mounted and a new WeatherPack connector on it. Have the old trans cooler lines out, cut back to just above the starter, and have the AN fittings on them. Came inside for a cup of java and I'm on my way back out now.
Bob
Old 04-03-2010, 07:50 PM   #1594
menace121978
menace121978's Avatar
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-03-2010, 09:48 PM   #1595
ERASER5
ERASER5's Avatar
Orifice tube systems do not have receivers. They have accumulators, which you have.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 04-03-2010, 10:19 PM   #1596
glock35ipsc
That's kind of what I meant when I said they are basically the same thing. It either has a receiver, or an accumulator. Not both. Yet they both share the same basic functions of filtering debris, storing liquid, and removing moisture.
Bob
Old 04-03-2010, 11:00 PM   #1597
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Good progress again! I say A/C is over rated...of course I say otherwise as soon as it hits 80* here. So, real A/C would be nice in the truck. (Instead of the "2-50 air")
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 04-05-2010, 10:11 AM   #1598
glock35ipsc
I know, right?! 'Cause it's like, we're in Colorado. And it snows year 'round!
My new helper, ready to....um, help:
It's back in!!! The connections are a little tight, but it'll work. I bent them up and toward center just a little. The bottom one in the pic will get either a 90° or 135° fitting so it can run up between the heater hoses and the rad hose, and the top on will get a 45° so it can come up and around the front side of the rad hose. The shroud is just sitting in there loose, it's not really that close to rad hose.:
Little did I know at the time, but the lines will easily clear the bracket I made for the MAF/air cleaner! I'll use a 90° fitting on the top so I can run it down and under the air cleaner:
I'm going to use all new lines, but I used the old stuff to mock it up so I could measure for the new lines:
Shop manual!
I cut both trans cooler lines off near the starter, then added the AN fittings and ran SS braided up to the radiator. The lines are now ran under the engine stand along the inside of the frame and completely out of the way of the compressor:
New fuel line (top), old fuel line (bottom):
I'll probably run to NAPA today and get the 90°, 135° and 45° fittings for the compressor end so I can see what is going to work the best. Once I figure that out, I'll have them crimp the 2 fittings on to about 4' of hose. Then I can figure out the best way to route them and mark the hoses where they need to be cut and the orientation of the fittings to be crimped on the other end.
Bob
Old 04-05-2010, 10:40 AM   #1599
6772owner
Gearhead
6772owner's Avatar
Looking good as always Bob, cant wait to see the truck again in July!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-05-2010, 12:49 PM   #1600
glock35ipsc
Thanks! I'm really looking forward to July.
I got everything ordered for the AC just a little while ago. Hose, fittings, o-rings, sealing washers, solder.... all that jazz from Docs Blocks. About $52 for all that! Not bad. Also ordered a new aluminum line that runs from the evaporator to the condenser.
I also bought a crimp tool for the hose fittings. I'm sure I could take the hoses to someone to do the crimping, but I like doing this stuff myself. And I know it will see use again. My brother needs to put new hoses on his 72 soon, and the 69 my Dad is building will be getting AC also.
Bob
