Old 04-02-2010, 09:15 PM   #1
Malibob
Malibob's Avatar
Inner Fenders, How Did You Cut Them? Picture Thread
So, I have air ride on my truck and always seem to be bottoming out in the inner fenders. I would like to keep my hood springs and not get too carried away with cutting out. How did you guys with air do it? Got any pictures? I am looking for tons of ideas here so let's see what you got!
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 04-04-2010, 05:35 PM   #2
Malibob
Malibob's Avatar
Re: Inner Fenders, How Did You Cut Them? Picture Thread
No one with cut inner fenders? I am thinking about how to cut a portion out of my inner fender and leave a portion that holds the spring. Anybody? I can go through build threads forever but am not having much luck finding the requested pics.
Flickr
Old 04-04-2010, 07:06 PM   #3
muddpile
muddpile's Avatar
I removed them completely, as they were 1/2" away sitting in park, and I'm not on air. If my truck had an engine under the hood, however, it looks like it would get dirty pretty fast. Depending on the offset of your rims, you may also have to slightly mod your outer fenders (the bolt strip anyways).
muddpile is offline   Reply With Quote
Old 04-04-2010, 10:47 PM   #4
javadoc
Hey Watch this...
javadoc's Avatar
This may seem like a stupid question, but how difficult is it to remove the inner fender wells? I'm sure it's all bolt-on/off, but do you have to remove the outer fenders? I'm asking b/c I need to replace my rusted out inners.
What have I gotten myself into now?
1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress
2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids
javadoc is offline   Reply With Quote
Old 04-05-2010, 12:54 AM   #5
muddpile
muddpile's Avatar
I removed my inners without removing my outers. There are 2-4 bolts on the firewall and rad support (It's been a whil ,I can't remember the exact # or locations...) and then the ones you see along the top of the fender.
Old 04-05-2010, 11:10 PM   #6
xratt
xratt's Avatar
I trimmed a little off two plces of the hinges. Moved the spring up a little bit at both ends. Still works great. Then I trimmed an arch in the inner fender at the squared off parts that run from the fire wall to the core support. Then bent the inner fender metal over the tires to match the arch. It did leave a gap in the inner fender at the fire wall end. But I think its better then having nothing. Now it does look home made. And one day I will replace it with a real wheel tub. But this works for now and it was free. I will load a few pics. The last pic is stock, before i cut it.
1966 C10, SB305, bagged.
1955 VW Buggy, 2.0L
1978 Honda CB550
http://67-72chevytrucks.com/vboard/s...9&goto=newpost
xratt is offline   Reply With Quote
Old 04-05-2010, 11:52 PM   #7
62 Bowtie
62 Bowtie's Avatar
not sure who it was maybe captain who makes spring relocator brackets that mount to the firewall. You can then eliminate the inner fenderwells or cut them to get the clearance you need
62 Bowtie is offline   Reply With Quote
Old 04-06-2010, 09:35 AM   #8
SCOTI
SCOTI's Avatar
Porterbuilt makes the hood hinge brackets for the firewall.
What size front tire is that?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
