04-04-2010, 09:06 AM | #1 |
Spare tire ?
Anyone have any better set-ups for mounting the spare tire? I see the factory one as being a potential PIA once my truck is lowered. I could just see a flat tire in the back and no way to get the spare out. I was thinking maybe one out of a toyota or as old as I am maybe just a AAA account?
04-04-2010, 09:10 AM | #2 |
Jonny
Re: Spare tire ?
If you're getting long in the tooth, maybe an AAA account would be best. other than that you could use or make a mount like in the 60-66 trucks that hold the spare vertical in front of the wheel tub inside the bed.
Edit: Here's a wite up from Tx Firefighter, took a minute to find it: http://kneeknockertruck.blogspot.com/
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 04-04-2010 at 09:16 AM. |
04-04-2010, 08:14 PM | #3 |
Re: Spare tire ?
Bump
Does everyone with a lowered truck carry the spare tire in the stock rack? |
04-05-2010, 07:20 AM | #4 |
Re: Spare tire ?
Mine's up in the bed.
If you don't feel like making a rack like Firefighter did (great job, by the way) you could probably find one of these in the junkyard or at a dealer. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-05-2010 at 07:21 AM. |
04-05-2010, 08:39 AM | #5 |
Re: Spare tire ?
I saw someone used a crank style, like you see on modern trucks. I am thinking about that, what do you guys think. not sure if I want the tire in the bed. I have a 3-4 lower kit on my '79 stepside
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
04-05-2010, 09:34 AM | #6 |
The One And Only !!!
Re: Spare tire ?
The 3" exhaust pipes done away with the stock spare placement on my 97, I mounted it flat in the front right corner of the bed with a 1/2" threaded rod welded to a square 3/16" thick plate bolted to the bed floor. I'll be doing the same with project 74, Since both these trucks are show only not dd's I have no problem with the spare placement since all either will ever haul is chairs/canopy and a cooler and the tonneau covers it all.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
04-05-2010, 04:37 PM | #7 |
3/4 Ton Rodder
Re: Spare tire ?
Here's mine. The bracket can be made out of some C channel and threaded rod. If you would like more pics of it, let me know.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
04-05-2010, 08:48 PM | #8 | |
Re: Spare tire ?
MHO - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-05-2010, 10:13 PM | #9 |
97' Tahoe 2dr/2wd
Re: Spare tire ?
anyone used a do-nut or space saver from a full size car? something smaller, that would fit under the bed?
