Jag Rearend
Has anyone wanted to put an XJ6 rear end under your truck to get IRS
Re: Jag Rearend
Yes, I've considered it.
Insane In The Membrane
Re: Jag Rearend
That get done quite a bit in the street rod world. I opted to go with a Corvette C4 rearend. The only down side to the Jag is trying to gear it and if you happen to break a u-joint or driveshaft you lose your brakes.
Cameron Gunlock Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750 |
Re: Jag Rearend
I also considered it as well, I have one in the backyard sitting and getting rained on. If you were to do it, you would most likely want to mount it without the cage and fabricate your own mounting system for the differential via some sort of crossmember. I was going to mount mine in the cage to keep the geometry but then I was gona have to notch the frame to conform to the jag housing, didn't want to do it. Plus parts are hard to come by and expensive $$$. To make it functional you would also want to keep the trailing arms that are attatched (which most street rodders get rid of). Check out posts by member (Dan in Pasadena) he has one mounted in its cage in his '46 pick up.
Whats wrong with your 8.8? |
![]() Join Date: Jun 2009
Re: Jag Rearend
I considered using the IRS as am using the front in my 57 and bought the front and rear axles as a pair. Considered using the de-caged option trouble was just too expensive a option for me so going to use a 8.8 axle as picked one up for peanuts. I would recommend you talk to Mike at C.W.I he can answer most questions you could think of and supply most parts http://www.cwiinc.com/index.html.
Re: Jag Rearend
47 c4 rearend s10 frame
Re: Jag Rearend
I had jag front and rear in a 66 C10 and it drove really well, and handled too , the rear was in it's cage and the truck was low, haven't got any pictures (sorry) , Here's a link to a company here in England that do mountings and all the straps etc to take one out of it's cage , send him an email -he's usually very helpful
http://www.popbrowns.co.uk/products2.html#TIESTRAP good luck dude, oh i'm just fitting one in a '38 chevy sedan delivery for a customer too
Here's the new video of the pro mod body i'm building http://www.youtube.com/watch?v=obJspWfEttc http://www.facebook.com/#/pages/The-...9609586?ref=ts The All Alone, Meet and Greet 2010, Going International. Starting July 3rd. 00:00hrs. where ever it is in the world where you are.. Looking to break the most members online record during the 24hr. marathon. Please help to promote this event. Edit Signature in your Control Panel to include..... "All Alone Meet & Greet 2010." http://67-72chevytrucks.com/vboard/s...d.php?t=393754 |
#8 | |
Navy Radioman Veteran
Re: Jag Rearend
Ken
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
